[OpenLayers-Dev] bbox strategy and zooming
Ivan Grcic ivan.grcic at geofoto.hr
Sat Nov 15 07:27:53 EST 2008
There you go: a ticket and an example
http://trac.openlayers.org/ticket/1835
http://dev.openlayers.org/sandbox/igrcic/openlayers/examples/strategy-bbox.html
Cheers, Ivan
On Fri, Nov 14, 2008 at 5:40 PM, Tim Schaub <tschaub at opengeo.org> wrote:
> Hey-
> Ivan Grcic wrote:
>> Hi, ive tried Tims patch and i must say im pretty happy with it. Tnx Tim!
>> I dont need to filter data depending on number of features
>> (maxfeatures), but to show all the currently available data for area,
>> then the cluster strategy jumps in and takes care that there are not
>> too many features rendered. Perfect.
>> Now the only problem is that one when upon activateing layer, it has
>> to be nudged a bit for features to load (moveend effect)
> Ivan, can you open a ticket and post an example that reproduces this
> specific problem?  It would be great to have a record of it.  Also, if
> you write back here with the ticket number, it would be good to have as
> part of this thread.
> Thanks,
> Tim
>> On Thu, Nov 13, 2008 at 9:08 PM, Eric Lemoine <eric.c2c at gmail.com> wrote:
>>> Thanks for putting this patch together Tim.
>>> Initially Chris wanted that the bbox strategy behave aggressively on
>>> zoom in, but, as an optimization, only if the number of features in
>>> the layer is not lower than the maxfeatures value set in the protocol.
>>> The change you're proposing wouldn't allow this. The change I proposed
>>> involved adding a new Integer option to the bbox strategy. If that
>>> option is null the strategy behaves as currently. If it's non-null
>>> then it behaves aggressively if the number of features in the layer is
>>> not lower than the option value.
>>> Chris was concerned with configuration data duplication - maxfeatures
>>> is kinda set in the protocol as well as in the strategy; which doesn't
>>> bother me actually.
>>> You may concerned with the fact that my proposed option targets a
>>> specific case (maxfeatures-parameterized requests) and doesn't address
>>> other, maybe more common, cases. I actually don't see other cases when
>>> a more aggressive mode makes sense, but that's probably just me.
>>> Cheers,
>>> Eric
>>> 2008/11/13, Tim Schaub <tschaub at opengeo.org>:
>>>> Hey-
>>>> Christopher Schmidt wrote:
>>>>> I'm still lost as to how to go about coding what I want :) I want to
>>>>> have maxfeatures, and more aggressive invalidation because of it. Any
>>>>> suggestinos as to how I might go about implementing that, or should I
>>>>> just toss together something and people will look at afterwards?
>>>> If you haven't already tossed something together, see the patch for
>>>> http://trac.openlayers.org/ticket/1830.
>>>> Set resFactor to 1 if you want to request features with every change in
>>>> resolution.
>>>> Tim
>>>>> Regards,
>>>> Tim Schaub
>>>> OpenGeo - http://opengeo.org
>>>> Expert service straight from the developers.
>>>> _______________________________________________
>>>> Dev mailing list
>>>> Dev at openlayers.org
>>>> http://openlayers.org/mailman/listinfo/dev
>>> Dev mailing list
> Tim Schaub
> Dev mailing list
Ivan Grcic
More information about the Dev mailing list
