[OpenLayers-Dev] re turning a value to openlayers via a web service.
kalisilvermist kalisilvermist at gmail.com
Wed Oct 1 10:02:27 EDT 2008
Hi all,
I am having a problem integrating my openlayers implementation into my
site..
I have created a map page that needs to display cached WMS tiles(served by
tilecache), this it seems to do fine mostly. What i then need to do is click
on the map, return the Lat/Lon to an Asynch Web Service written in C# which
then launches the manifoldgis interop component to allow me to perform a
search within the geometry on the database. Now the query works,the
webservice works,the page works for most things however i cannot see what i
am doing wrong that my web service is not returning a result object or
rather it is but it's empty !
Here is the openlayers code.
<script type="text/javascript">
	    var map, layer, x, y, markersLayer;
	    OpenLayers.IMAGE_RELOAD_ATTEMPTS = 3;
	    OpenLayers.Util.onImageLoadErrorColor = "transparent";
	    //Control Click Handler
	    OpenLayers.Control.Click = OpenLayers.Class(OpenLayers.Control, {
	        defaultHandlerOptions: {
	            'single': true,
	            'double': false,
	            'pixelTolerance': 0,
	            'stopSingle': false,
	            'stopDouble': false
	        initialize: function(options) {
	            this.handlerOptions = OpenLayers.Util.extend(
                        {}, this.defaultHandlerOptions
	            OpenLayers.Control.prototype.initialize.apply(
                        this, arguments
	            this.handler = new OpenLayers.Handler.Click(
                        this, {
                            'click': this.trigger
                        }, this.handlerOptions
	        trigger: function(e) {
	            markerlayer.removeFeatures(markerlayer.features);
	            //map.removePopup(popup);
	            var lonlat = map.getLonLatFromViewPortPx(e.xy);
	            //var proxy =
Service.select_id_centrePoint_Geom_byLatLon(lonlat.lat,lonlat.lon,
onWebServiceCallBack);
	            var proxy =
Service.select_id_centrePoint_Geom_byLatLon(lonlat.lat,lonlat.lon,onWebServiceCallBack);
	            //var proxy = Service._Echo(lonlat.toString(),
	    function onWebServiceCallBack(result, userContext, methodName)
	        var temp = new Array();
	        var s = result.toString();
	        temp = s.split(',');
	        var cmaID = temp[0];
	        Lat = temp[1];
	        Lon = temp[2];
	        var marker = new OpenLayers.Feature.Vector(
                        new OpenLayers.Geometry.Point(Lon, Lat), {
                            externalGraphic:
"http://localhost/TileCache/Images/marker-gold.png",
                            backgroundGraphic: "../Images/marker-gold.png",
                            backgroundXOffset: 0,
                            backgroundYOffset: -7,
                            graphicZIndex: 1100,
                            backgroundGraphicZIndex: 1000,
                            pointRadius: 10
	        //markerlayer.addMarker(marker);
	        markerlayer.addFeatures(marker);
	        map.addLayer(markerlayer);
	        var popup = new OpenLayers.Popup("Erf Info", "chickenlicken",
                                          new OpenLayers.Size(200, 600),
                                          "Clicked at:= Longitude :" + Lon +
" \n Latitude :" + Lat , true);
	        popup.setOpacity(0.7);
	        map.addPopup(popup);
	        alert(cmaID);
	    function init() {
	        var street_OverLay, erven_OverLay
	        x = 18.43678;
	        y = -33.9068;
	        //specify Resolution array - zooms
	        var options = { resolutions: new Array(0.00001867185,
0.0000093359375, 0.00000466796875, 0.000002333984375, 0.0000011669921875),
'maxExtent': new OpenLayers.Bounds(bbox = 18.13232, -34.39155, 19.01818,
-33.39165), restrictedExtent: new OpenLayers.Bounds(bbox = 18.13232,
-34.39155, 19.01818, -33.39165) };
	        // set theme:null to enable style editing on the rows
	        //create a new map object
	        map = new OpenLayers.Map($('map'), options);
	        //set overlay
	        street_OverLay = new OpenLayers.Layer.WMS("Cape Metropolitan
Council",
                "tilecache.py?TRANSPARENT=true",
                { layers: "Municipal_Overlay", transparent: "true",
'maxExtent': new OpenLayers.Bounds(18.52, -34.62, 19.28, -33.77), format:
"image/png" }, { alpha: true });
	        street_OverLay.setZIndex(0);
	        street_OverLay.setVisibility(true);
	        street_OverLay.setIsBaseLayer(true);
	        map.addLayer(street_OverLay);
	        //create the erven overlay and set it to be invisible
	        //erven_OverLay = new OpenLayers.Layer.WMS( "Erven Overlay",
	        //    "tilecache.py?TRANSPARENT=true",
	        //    {layers: "Erven_Overlay",transparent: "true", format:
"image/png",minZoomLevel: 0, maxZoomLevel: 1 },{alpha:true});
	        //	erven_OverLay.setZIndex(100);
	        //   erven_OverLay.setVisibility(false);
	        //	/erven_OverLay.setIsBaseLayer(true);
	        //    map.addLayer(erven_OverLay);
	        //code to add marker layer
	        markerlayer = new OpenLayers.Layer.Vector(
                "Marker Drop Shadows",
                    styleMap: new OpenLayers.StyleMap({
                        // Set the external graphic and background graphic
images.
                    externalGraphic:
                        graphicZIndex: 11,
                        backgroundGraphicZIndex: 10,
                        pointRadius: 10
                    isBaseLayer: false,
                    displayInLayerSwitcher: false,
                    rendererOptions: { yOrdering: true }
	        map.addLayers(markerlayer);
	        // Add The Control Box(es) to the page
	        map.addControl(new OpenLayers.Control.LayerSwitcher()); //layer
switching tool
	        //var options = {div:$('mouseco')};
	        map.addControl(new OpenLayers.Control.MousePosition()); // mouse x
and y co-ordinates
	        //map.removeControl(OpenLayers.Control.PanZoom());
	        map.removeControl(map.controls[1])
	        map.addControl(new OpenLayers.Control.PanZoomBar()); //Zoom Slider
I think
	        options = { div: $('labs') };
	        //map.addControl(new OpenLayers.Control.ScaleLine(options)); // to
give an idea of sacale
	        //set the base layer this is the primary visible layer
	        //options = {div: $('powered')};
	        var click = new OpenLayers.Control.Click();
	        map.addControl(click);
	        click.activate();
	        map.setBaseLayer("Cape Metropolitan Council");
	        //add the overview map
	        //map.addControl(new OpenLayers.Control.OverviewMap({layers:
"Municipal_Overlay",isSuitableOverview: function() {return true;}}));
	        //set the zoom and longlat of startup
	        map.setCenter(new OpenLayers.LonLat(x, y), 0);
	        if (!map.getCenter()) map.zoomToMaxExtent();
    </script>
Here is the C# Web Method
  [WebMethod]
            public string select_id_centrePoint_Geom_byLatLon(double
Latitude, double Longitude)
                StringBuilder sb = new StringBuilder();
                string s;
                MapServer mapServer = new MapServer();
                string State = "";
                mapServer.Create(Server.MapPath("config.txt"), State, "");
                Manifold.Interop.Query q =
(Manifold.Interop.Query)mapServer.Document.ComponentSet["Select_Erf_CentrePoint_and_Cma_ID"];
                q.ParameterSet["Lat"].Value = Latitude.ToString();
                q.ParameterSet["Lon"].Value = Longitude.ToString();
                q.Run();
                Manifold.Interop.Table T = q.Table;
                foreach (Manifold.Interop.Record r in T.RecordSet)
                    foreach (Manifold.Interop.Column c in T.ColumnSet)
                        sb.Append(r.get_Data(c.Name) + "|");
                s = sb.ToString();
                return s;
            [WebMethod]
            public string _Echo(string input)
                return input;
            [WebMethod]
            public string _WS_Test()
                return "Hello World";
and here is the aspx page
 </head>
  <body onload="init()">
  <form runat="server">
  <asp:ScriptManager runat="server" ID="ScriptManager1"
EnablePageMethods="True">
        <Services>
            <asp:ServiceReference
Path="http://localhost/MapService_Site/Service.asmx" />
        </Services>
        </asp:ScriptManager>
    </form>
	<div id="map">
	<div id="chickenlicken" style="position:relative;background-color: red;
color: white; font-size: 120%;left:110px;top:150px"></div>
    <div id="labs"><div id="outPutDiv"></div></div>
	<div id="powered">Powered By CMAInfo</div>
	</div>
   </body>
</html>
Really hope that someone will be able to assist me or perhaps provide a
better way. Web services are important in our project though because we need
to be able to offer various online services including mapservices.
Greetings from Cape Town(South Africa)
Sandro
View this message in context: http://www.nabble.com/returning-a-value-to-openlayers-via-a-web-service.-tp19761190p19761190.html
Sent from the OpenLayers Dev mailing list archive at Nabble.com.
More information about the Dev mailing list
