[OpenLayers-Dev] openlayers problem in IE6
Nathan Gerber
ngerber999 at gmail.com
Sat Oct 18 11:16:31 EDT 2008
Sorry about that I should have read your email a bit closer, I made an
assumption and well it made something out of me :-) I'm afraid I haven't
toyed too much with events triggered by vector layers so somebody else will
have to help you out with this one.
Nathan Gerber
2008/10/18 dequan chen <cdqrain at gmail.com>
> thanks ngerber.
> but you may misunderstand my issue.
> It doesn't relate to PNG image.
> I use some OpenLayers.Layer.Vector as map layers. these layer will
> display LineString, Polygon etc. and each Vector Layer has its
> JavaScript event. But, in IE6, the top vector layer covers the map
> completely. It will result in the lower vector layer's event can not
> be responsed.
> In IE7 or FireFox, it works well. Every vector layer's event can be
> triggered.
> 2008/10/17, Nathan Gerber <ngerber999 at gmail.com>:
> > If you are using PNG images this is a known issue and there is little you
> > can do beyond trying another format such as GIF or telling your users to
> get
> > a more modern web browser. There is a hack to enable the use of alpha
> > transparency int he PNG images within IE6 but it has a severe effect on
> > performance.
> > Nathan Gerber
> > 2008/10/16 dequan chen <cdqrain at gmail.com>
> >> hi.
> >> I use more than one openlayers vector layer to overlay the map. every
> >> layer
> >> has its event. in IE6, the upper layer covers completely the lower
> layer.
> >> so, the other vector layer event can not be triggered. in IE7 or
> firefox,
> >> there's no this issue.
> >> I try to render the vector layer div border, and find the div fill the
> >> entire map. in IE7 or firefox, the border shrinks to the top left
> corner.
> >> so the layer don't cover the lower layer.
> >> how to solve this problem ? thanks. :-)
> >> _______________________________________________
> >> Dev mailing list
> >> Dev at openlayers.org
> >> http://openlayers.org/mailman/listinfo/dev
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20081018/b37f1ae2/attachment.html
More information about the Dev
