[OpenLayers-Dev] openlayers problem in IE6
Eric Lemoine eric.c2c at gmail.com
Sun Oct 19 03:08:53 EDT 2008
Hi. With multiple vector layers events work only for the elements of
the layer on top of the others. I'm suprised you're observing
different behavior on IE6, IE7 and FF with that respect. A simple
example would help us understand the issue. Eric
2008/10/16, dequan chen <cdqrain at gmail.com>:
> hi.
> I use more than one openlayers vector layer to overlay the map. every layer
> has its event. in IE6, the upper layer covers completely the lower layer.
> so, the other vector layer event can not be triggered. in IE7 or firefox,
> there's no this issue.
> I try to render the vector layer div border, and find the div fill the
> entire map. in IE7 or firefox, the border shrinks to the top left corner. so
> the layer don't cover the lower layer.
> how to solve this problem ? thanks. :-)
More information about the Dev mailing list
