[OpenLayers-Dev] Format.WMC and scale
bartvde at osgis.nl
bartvde at osgis.nl
Mon Oct 27 03:39:42 EDT 2008
"In WMC you can have only a MinScaleDenominator or a
MaxScaleDenominator."
Next to the option of having both I meant ofcourse.
Best regards,
Bart
> Hi Eric,
>> On your side have you figured out why the calculated minScale is
>> different than the minScale value in the options?
> Yes, I believe this happens when there is only a minscale or maxscale, so
> not both. In WMC you can have only a MinScaleDenominator or a
>> Regarding WMC, I think it makes that WMC write uses layer.minScale.
>> Indeed, we need to deal with cases where the layer wasn't built out of
>> WMC and no minScale option was set in the layer.
> Right, that makes sense, I understand the reasoning now. Thanks.
> Best regards,
> Bart
>> Hi Bart
>> We've also experienced unexpected minScale/maxScale values here at
>> Camptocamp. So far we haven't had a chance to investigate the problem.
>> Eric
>> 2008/10/23, bartvde at osgis.nl <bartvde at osgis.nl>:
>>> Hi list,
>>> question about the Format.WMC code.
>>> When it reads a scale from a WMC doc, it is stored in the options array
>>> of
>>> the layer.
>>> But when it writes, it uses the minScale or maxScale property of the
>>> layer.
>>> Why is this? I would expect when writing to also use the
>>> options.minScale
>>> and options.maxScale.
>>> In my situation options.minScale is 35000 (the correct value) and
>>> layer.minScale is 10000000.999999998, don't ask me why :-). So when
>>> serializing the WMC the wrong information is written.
>>> Best regards,
>>> Bart
>>> Dev mailing list
>>> Dev at openlayers.org
>>> http://openlayers.org/mailman/listinfo/dev
> Dev mailing list
More information about the Dev
