[OpenLayers-Dev] Format.WMC and scale
Tim Schaub tschaub at opengeo.org
Mon Oct 27 23:46:34 EDT 2008
Hey Bart-
bartvde at osgis.nl wrote:
> Hi list,
> question about the Format.WMC code.
> When it reads a scale from a WMC doc, it is stored in the options array of
> the layer.
> But when it writes, it uses the minScale or maxScale property of the layer.
Are you using WMC v1.1?  If so, it should be writing from
layer.options.minScale and layer.options.maxScale (not layer.minScale
and layer.maxScale).
http://trac.openlayers.org/browser/trunk/openlayers/lib/OpenLayers/Format/WMC/v1_1_0.js#L86
Let me know if you are seeing something different.
> Why is this? I would expect when writing to also use the options.minScale
> and options.maxScale.
> In my situation options.minScale is 35000 (the correct value) and
> layer.minScale is 10000000.999999998, don't ask me why :-). So when
> serializing the WMC the wrong information is written.
Are you saying that the problem is the change in precision?
If so, we could open a ticket to correct this for
OpenLayers.Util.getResolutionFromScale and getScaleFromResolution (so
that one is the compliment of the other).
If you (or Eric) think that maxScale is being disregarded when passed as
a layer option, please provide a test case.  We corrected the grossest
case where this was occurring (in initResolutions) in r6332.
http://trac.openlayers.org/changeset/6332
(See the test cases there, would be good to have ones that don't pass if
there is a problem.)
Tim
> Best regards,
> Bart
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
Tim Schaub
OpenGeo - http://opengeo.org
Expert service straight from the developers.
More information about the Dev mailing list
