[OpenLayers-Dev] Problem with the developpement of a "overlay Strategy"
Tim Schaub tschaub at opengeo.org
Mon Oct 27 23:08:01 EDT 2008
Hey-
Jerome Freyre wrote:
> Hi everybody,
> Currently I am trying to developp a new strategy (based on
> OpenLayers.Strategy.Cluster) that can modify the order of features (bigger
> features go downer and small one go higher) to display features with correct
> "overlay" or "superposition".
> To do that, I found that I have to order my features.
> Actually, I am loading my features with HTTP protocol (see:
> http://www.nabble.com/Problem-with-Protocol-HTTP-and-vector-layer-tt20088456.html
> My "sort algorithm" seems to work because it is ordering features based on
> the "overlayAttribute".
> The problem appears when I select a feature that is "downer". When I
> unselect it, the feature goes "higher" than the smaller one and stays like
> this.
> Has somebody got an idea to resolve this problem?
> My strategy function :
>         if(this.features.length >= 2) {
> 			var tempArray = this.features;
> 			//alert('count = ' + this.features.length);
> 			for (var i=0; i<this.features.length; i++) {
> 				for(var j=this.features.length-1; j>i;j--) {
> 					//alert('Comparaison de ' +
> this.features[j].attributes[this.overlayAttribute] + ' et ' +
> this.features[j-1].attributes[this.overlayAttribute]);
> 					if (parseInt(this.features[j].attributes[this.overlayAttribute]) >
> parseInt(this.features[j-1].attributes[this.overlayAttribute])) {
> 						var tmp = this.features[j];
> 						this.features[j] = this.features[j-1];
> 						this.features[j-1] = tmp;
Also, looks like you should be using the built in array.sort method in
this case.
http://www.w3schools.com/jsref/jsref_sort.asp
> 		var attr = "";
> 		for(var i=0; i<this.features.length; ++i) {
> 			attr += this.features[i].attributes[this.overlayAttribute] + ' \\ ';
> 	if(this.features.length > 0) {
>                  this.clustering = true;
>                  // A legitimate feature addition could occur during this
>                  // addFeatures call.  For clustering to behave well,
> features
>                  // should be removed from a layer before requesting a new
> batch.
> 				 this.layer.removeFeatures();
>                  this.layer.addFeatures(this.features);
>                  this.clustering = false;
Tim Schaub
OpenGeo - http://opengeo.org
Expert service straight from the developers.
More information about the Dev mailing list
