[OpenLayers-Dev] Vector layer not shown well in IE7
Damiano Morosi
damiano.morosi at gmail.com
Fri Oct 31 04:56:15 EDT 2008
I correct: the problem is present only if you add two point features on two
different vector layers.
Stay tuned...
2008/10/31 Damiano Morosi <damiano.morosi at gmail.com>
> Hi all,
> I have a problem with vetor layer and IE7. The following (simplified) code
> works well in Firefox but unsurprisingly not in IE7, where the point is
> always displayed at the upper left corner, wherever you position it in the
> map.
> <script
> type="text/javascript">
> var map, layer, pointLayer,
> path;
> var result_style =
> OpenLayers.Util.applyDefaults({
> strokeWidth:
> 3,
> strokeColor:
> "#ff0000",
> fillOpacity: 100
> }, OpenLayers.Feature.Vector.style['default']);
> function init(){
> var mapOptions = { ... }
> map = new OpenLayers.Map( 'map', mapOptions);
> layer = new OpenLayers.Layer.TileCache(
> "basic",
> ["http://213.199.15.252/tilecache"],
> 'basic');
> pointLayer = new OpenLayers.Layer.Vector("Zoom",
> {styl
> e: point_style});
> map.addLayers([layer, pointLayer]);
> function showPoint(lon, lat) {
> var point_wkt = 'POINT('+lon+'
> '+lat+')';
> parser = new
> OpenLayers.Format.WKT();
> var point_feat =
> parser.read(point_wkt);
> pointLayer.destroyFeatures();
> pointLayer.addFeatures([point_feat]);
> map.panTo(new OpenLayers.LonLat(lon, lat));
> </script>
> Thank you, please ask if you need more details.
> Damiano Morosi
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20081031/624ccfa8/attachment.html
More information about the Dev
