[OpenLayers-Dev] Vector layer not shown well in IE7
Damiano Morosi
damiano.morosi at gmail.com
Fri Oct 31 05:05:41 EDT 2008
New update: the problem is present also if you add more than 1 point feature
in the same vector layer. The first point is placed well, the second... no.
2008/10/31 Damiano Morosi <damiano.morosi at gmail.com>
> I correct: the problem is present only if you add two point features on two
> different vector layers.
> Stay tuned...
> Hi all,
>> I have a problem with vetor layer and IE7. The following (simplified) code
>> works well in Firefox but unsurprisingly not in IE7, where the point is
>> always displayed at the upper left corner, wherever you position it in the
>> map.
>> <script
>> type="text/javascript">
>> var map, layer, pointLayer,
>> path;
>> var result_style =
>> OpenLayers.Util.applyDefaults({
>> strokeWidth:
>> 3,
>> strokeColor:
>> "#ff0000",
>> fillOpacity: 100
>> }, OpenLayers.Feature.Vector.style['default']);
>> function init(){
>> var mapOptions = { ... }
>> map = new OpenLayers.Map( 'map', mapOptions);
>> layer = new OpenLayers.Layer.TileCache(
>> "basic",
>> ["http://213.199.15.252/tilecache"],
>> 'basic');
>> pointLayer = new OpenLayers.Layer.Vector("Zoom",
>> {styl
>> e: point_style});
>> map.addLayers([layer, pointLayer]);
>> function showPoint(lon, lat) {
>> var point_wkt = 'POINT('+lon+'
>> '+lat+')';
>> parser = new
>> OpenLayers.Format.WKT();
>> var point_feat =
>> parser.read(point_wkt);
>> pointLayer.destroyFeatures();
>> pointLayer.addFeatures([point_feat]);
>> map.panTo(new OpenLayers.LonLat(lon, lat));
>> </script>
>> Thank you, please ask if you need more details.
>> Damiano Morosi
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20081031/6ad45040/attachment.html
More information about the Dev
