[OpenLayers-Dev] Vector features don't display at level 0
Christopher Schmidt
crschmidt at metacarta.com
Fri Sep 5 08:05:15 EDT 2008
On Fri, Sep 05, 2008 at 07:37:57AM -0400, Alexandre Dube wrote:
> Hi devs,
> I use OpenLayers 2.6 and I have an issue while using vector features. I have a WFS layer that displays features on different zoom levels. When I initialize the zoom level to anything but 0, features are displayed. If I then go back to level 0, features are displayed.
> But, when I start at level 0, features are not displayed. I then zoom to level 1 and here they are. Back to 0 they're here again. Also, if I start at level 0 ( features not here ), and unselect the layer in the layerswitcher and reselect it, features appear.
> When starting at level 0, the features array contain features. The layer is inRange and is Visible so it should show its features ?
> I tested my application with the trunk and the features are displayed at level 0 on start. I was wondering if this is a known bug and if it has already been fixed.
Er, if it works in trunk, then isn't the answer to this an obvious yes?
Regards,
Christopher Schmidt
MetaCarta
More information about the Dev
