[OpenLayers-Dev] Vector features don't display at level 0
Alexandre Dube
adube at mapgears.com
Fri Sep 5 08:14:58 EDT 2008
Ok, I'll just have to wait for the next release then :) ( I wasn't sure
if the trunk was actually as the next release would be. )
Thanks,
Alexandre
Christopher Schmidt wrote:
> On Fri, Sep 05, 2008 at 07:37:57AM -0400, Alexandre Dube wrote:
>> Hi devs,
>> I use OpenLayers 2.6 and I have an issue while using vector features. I have a WFS layer that displays features on different zoom levels. When I initialize the zoom level to anything but 0, features are displayed. If I then go back to level 0, features are displayed.
>> But, when I start at level 0, features are not displayed. I then zoom to level 1 and here they are. Back to 0 they're here again. Also, if I start at level 0 ( features not here ), and unselect the layer in the layerswitcher and reselect it, features appear.
>> When starting at level 0, the features array contain features. The layer is inRange and is Visible so it should show its features ?
>> I tested my application with the trunk and the features are displayed at level 0 on start. I was wondering if this is a known bug and if it has already been fixed.
> Er, if it works in trunk, then isn't the answer to this an obvious yes?
> Regards,
Alexandre Dubé
Mapgears
www.mapgears.com
More information about the Dev
