[OpenLayers-Dev] WFSDescribeFeatureType request in 2.7-rc1 extra "?"
Eric Lemoine eric.c2c at gmail.com
Mon Sep 8 15:20:16 EDT 2008
Hi Alexandre.
Yes, IIRC there already is a ticket for this, and a patch. If it
worked in 2.6 and this is therefore a regression then change the
ticket's milestone to 2.7 and we'll fix it during the RC cycle.
In the mean time you may want to know that you can pass a params
object in place of a params string to loadURL, with an object it
should work as expected. I understand that you get the params string
from the WFS object, but you may be able to be able to convert it back
to an object using some method in Util (sorry i can't look this up for
you right now).
Eric
2008/9/8, Alexandre Dube <adube at mapgears.com>:
> I tried an other request and got the same problem.  In Requests.js at
> line 90, that's where it gets its extra "?"
> OpenLayers.loadURL(
>     "/bdga/getLayersByType.php?mapfile="+szMapfile, '', this, setLayers);
> The request becomes :
> .../bdga/getLayersByType.php?mapfile=/mypath/bdga.map?
> Alexandre
> Alexandre Dube wrote:
>> Hi devs,
>>   I noticed a new strange behavior with OpenLayers 2.7-rc1 using
>> WFSDescribeFeatureType format.
>>   Here's the request I'm using :
>>         var sUrl =  olWFSRoads.getFullRequestString({
>>             REQUEST: "DescribeFeatureType",
>>             SERVICE: "WFS",
>>             TYPENAME: "BDGA_ROUTE_L_ARC",
>>             VERSION: "1.0.0"
>>         OpenLayers.loadURL(sUrl, '', this, setRoadAttributes);
>>   Here's the end of the URL in :
>>   2.6 : &SRS=EPSG%3A32198&TYPENAME=BDGA_ROUTE_L_ARC
>>   2.7 : &SRS=EPSG%3A32198&TYPENAME=BDGA_ROUTE_L_ARC?
>>   With 2.7, I get the following error : Invalid typename
>> (BDGA_ROUTE_L_ARC?).  There should not be a "?" at the end of the request.
>>   Then, I realized that "typename" is already at the beginning of the
>> request so I just quoted //TYPENAME: "BDGA_ROUTE_L_ARC", and it worked,
>> but the "?" is still there ( at the end ) but it didn't affect
>> anything.  I don't know if this extra "?" could appear elsewhere ( on
>> other requests )
>>  Should I open a ticket for this ?
> Alexandre Dubé
> Mapgears
> www.mapgears.com
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
More information about the Dev mailing list
