[OpenLayers-Dev] WFSDescribeFeatureType request in 2.7-rc1
extra "?"
Eric Lemoine
eric.c2c at gmail.com
Mon Sep 8 15:26:37 EDT 2008
Ticket is #1616. Cheers. Eric
2008/9/8, Eric Lemoine <eric.c2c at gmail.com>:
> Hi Alexandre.
> Yes, IIRC there already is a ticket for this, and a patch. If it
> worked in 2.6 and this is therefore a regression then change the
> ticket's milestone to 2.7 and we'll fix it during the RC cycle.
> In the mean time you may want to know that you can pass a params
> object in place of a params string to loadURL, with an object it
> should work as expected. I understand that you get the params string
> from the WFS object, but you may be able to be able to convert it back
> to an object using some method in Util (sorry i can't look this up for
> you right now).
> Eric
> 2008/9/8, Alexandre Dube <adube at mapgears.com>:
>> I tried an other request and got the same problem. In Requests.js at
>> line 90, that's where it gets its extra "?"
>> OpenLayers.loadURL(
>> "/bdga/getLayersByType.php?mapfile="+szMapfile, '', this, setLayers);
>> The request becomes :
>> .../bdga/getLayersByType.php?mapfile=/mypath/bdga.map?
>> Alexandre
>> Alexandre Dube wrote:
>>> Hi devs,
>>> I noticed a new strange behavior with OpenLayers 2.7-rc1 using
>>> WFSDescribeFeatureType format.
>>> Here's the request I'm using :
>>> var sUrl = olWFSRoads.getFullRequestString({
>>> REQUEST: "DescribeFeatureType",
>>> SERVICE: "WFS",
>>> TYPENAME: "BDGA_ROUTE_L_ARC",
>>> VERSION: "1.0.0"
>>> OpenLayers.loadURL(sUrl, '', this, setRoadAttributes);
>>> Here's the end of the URL in :
>>> 2.6 : &SRS=EPSG%3A32198&TYPENAME=BDGA_ROUTE_L_ARC
>>> 2.7 : &SRS=EPSG%3A32198&TYPENAME=BDGA_ROUTE_L_ARC?
>>> With 2.7, I get the following error : Invalid typename
>>> (BDGA_ROUTE_L_ARC?). There should not be a "?" at the end of the
>>> request.
>>> Then, I realized that "typename" is already at the beginning of the
>>> request so I just quoted //TYPENAME: "BDGA_ROUTE_L_ARC", and it worked,
>>> but the "?" is still there ( at the end ) but it didn't affect
>>> anything. I don't know if this extra "?" could appear elsewhere ( on
>>> other requests )
>>> Should I open a ticket for this ?
>> Alexandre Dubé
>> Mapgears
>> www.mapgears.com
>> Dev mailing list
>> Dev at openlayers.org
>> http://openlayers.org/mailman/listinfo/dev
More information about the Dev
