[OpenLayers-Dev] ArcGIS server 9.2 support for OL
RajC rajchundur at gmail.com
Mon Sep 15 09:43:14 EDT 2008
Hi all
Using a combination of the code posted by AugustTown
using OpenLayers.Layer.AgsTiled
http://dev.openlayers.org/sandbox/august/openlayers/openlayers-2.6/examples/ags/agsComprehensive-ext.html
as well as the code snippet posted by matthewsnape @
http://www.nabble.com/ArcGIS-server-9.2-support-for-OL-ts9691195.html
I was able to get the AGS cache to line up correctly for atleat the 3-4 zoom
levels i tried.
Need to test for other levels and i'll post my results after that.
Thanks to all who posted their code and shared their experiences.
RajC
mpriour wrote:
> Post the configuration options for your map, AGS layer and KaMap layer.
> Also if you could attach or share the AGS XML config file, that would be
> helpful too
> Matt Priour
> RajC wrote:
>> I am trying to overlay AGS created cache layer over a KaMAP created Cache
>> Layer of the same data set.
>> However, even after following the tips in this forum, I am unable to get
>> them lined up.
>> The AGS layer is not lining up at the correct coord position. I have
>> generated the AGS cache and set the layer creation with the right extent
>> and tile origin.
View this message in context: http://www.nabble.com/ArcGIS-server-9.2-support-for-OL-tp9691195p19493203.html
Sent from the OpenLayers Dev mailing list archive at Nabble.com.
More information about the Dev mailing list
