[OpenLayers-Dev] Vector layer marker drifting with Google base
map
Sean Gillies
sgillies at frii.com
Thu Sep 18 12:42:08 EDT 2008
Thanks, Eric.
Eric Lemoine wrote:
> Hi Sean. You need to use ESPG:900913 and set sphericalMercator to true
> in the options passed to the constructor of the Google layer. There's
> a page on OpenLayers' wiki about this, search SphericalMercator using
> the wiki's search engine. Cheers. Eric
> 2008/9/18, Sean Gillies <sgillies at frii.com>:
>> Hi all,
>> I'm trying to overlay a point vector layer symbolized with drop shadow
>> markers over a base Google layer. Things look fine, the marker is where
>> I expect it, until I pan and then the position of the marker begins to
>> drift approximately half height of the marker in the panning direction.
>> I'm using the javascript served from openlayers.org/api/OpenLayers.js.
>> Known bug? Programmer error? Script below:
>> <script type="text/javascript">
>> var map, base, marker, coords;
>> var SHADOW_Z_INDEX = 10;
>> var MARKER_Z_INDEX = 11;
>> function init() {
>> map = new OpenLayers.Map('map');
>> base = new OpenLayers.Layer.Google(
>> "Base", {
>> isBaseLayer: true,
>> type: G_PHYSICAL_MAP,
>> marker = new OpenLayers.Layer.Vector(
>> "Marker",
>> styleMap: new OpenLayers.StyleMap({
>> externalGraphic:
>> "http://openlayers.org/dev/img/marker-gold.png",
>> backgroundGraphic:
>> "http://openlayers.org/dev/examples/marker_shadow.png",
>> backgroundXOffset: 0,
>> backgroundYOffset: -7,
>> graphicZIndex: MARKER_Z_INDEX,
>> backgroundGraphicZIndex: SHADOW_Z_INDEX,
>> pointRadius: 10
>> reproject: true,
>> isBaseLayer: false,
>> projection
>> rendererOptions: {yOrdering: true}
>> coords = pleiades_oljs.centroid.coordinates;
>> map.addLayers([base, marker]);
>> map.setCenter(new OpenLayers.LonLat(coords[0], coords[1]), 5);
>> marker.features.push(
>> new OpenLayers.Feature.Vector(
>> new OpenLayers.Geometry.Point(coords[0], coords[1])
>> </script>
>> I'm grateful for any suggestions.
>> Sean
>> Dev mailing list
>> Dev at openlayers.org
>> http://openlayers.org/mailman/listinfo/dev
More information about the Dev
