[OpenLayers-Dev] Development regarding WFS layer/protocol
Björn Harrtell bjorn.harrtell at gmail.com
Fri Sep 19 16:56:12 EDT 2008
I have been making a serious (relatively? :) attempt at understanding what
is to be done regarding Protocol.WFS and related classes. I looked at it
from the angle in which it would be useful for me in the case I described
before.
* the standard WFS-T
* Fixed and Save (and perhaps SaveGreedy) strategy
From I can gather none of these are far from complete, but what I'm missing
is option to filter the input in Fixed strategy. I noticed that the trunk
version of BBOX strategy looks for additional filters in the layer and while
it might be a good place put the additional filter I can't see any
indication that Layer actually is supposed to support such a property. If it
should it should be documented and used by fixed strategy also?
I would like to to implement this before beeing able to do serious testing.
I nice thing is that I could test stuff directly in a real world case where
I'm using (successfully) the clumsy old Layer.WFS way with a temp layer. But
before that I would like to confirm that I got the right idea...
A question on the side... why are some methods declared "JSONy" i.e 'read'
instead of read?
/Björn
On Wed, Sep 17, 2008 at 2:10 AM, Tim Schaub <tschaub at opengeo.org> wrote:
> Hey-
> Björn Harrtell wrote:
> > Hi devs,
> > I'm coding an application that uses OL vector editing and WFS
> > transactions quite heavily.
> > I use a temporary OpenLayers.Layer.Vector for editing, moving stuff to a
> > OpenLayers.Layer.WFS as the user makes edits. This is a bit clumsy and
> > complicated but works. The reason why I'm doing this is because
> > OpenLayers.Layer.WFS only supports GET and is also loading features on
> > demand (hmm is this correct?) which doesn't fit my needs. Note that I do
> > not add the OpenLayers.Layer.WFS to a map, I only use create/commit the
> > WFS transactions.
> > I would like to use something like a static/manually triggered WFS
> > (supporting POST and filtering) source to an OpenLayers.Layer.Vector
> > that syncs changes to the WFS source which then can be commited
> > programmatically.
> > Is this sort of what OpenLayers.Protocol.WFS (which I think is beeing
> > worked on?) is supposed to be used for? Or would it be sensible to make
> > something more of OpenLayers.Layer.WFS instead?
> Yes, this is exactly the job for a WFS protocol.  As Eric mentions, the
> work is mostly in the vector-behavior sandbox.  I'll make an effort to
> update that and to get a patch ready for the trunk.
> My hope is to get the WFS protocol in the trunk before the end of next
> week.  Any help you can contribute would be appreciated.
> Watch the WFS protocol ticket [1] for updates from me, and leave any
> comments/patches there that you put together.
> Tim
> [1] http://trac.openlayers.org/ticket/1648
> > Either way, I'm interested in (trying) to help out if this seems like
> > something you would like to support in OL, and can probably do it as a
> > part of the current project as it would simplify things for me I think.
> > Regards,
> > Björn Harrtell
> > GIS Consultant
> > SWECO Position AB
> > <http://www.swecogroup.com/en/Sweco-group/Services/Geographic-IT/>
> > Dev mailing list
> > Dev at openlayers.org
> > http://openlayers.org/mailman/listinfo/dev
> Tim Schaub
> OpenGeo - http://opengeo.org
> Expert service straight from the developers.
> Dev mailing list
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20080919/9b975f97/attachment.html
More information about the Dev mailing list
