[OpenLayers-Dev] Development regarding WFS layer/protocol
Eric Lemoine
eric.c2c at gmail.com
Mon Sep 22 01:31:23 EDT 2008
Hi Björn
You are right that the prototype of Layer.Vector should include a
"filter" property.
You are right that Strategy.Fixed should look pass the layer filter to
the protocol's read method.
These two issues would deserve tickets I think.
We need quoting "delete" because it's a js reserved word. For the sake
of uniformity we've also been quoting the other protocol verbs, namely
"read", "create" and "update".
Eric
2008/9/19, Björn Harrtell <bjorn.harrtell at gmail.com>:
> I have been making a serious (relatively? :) attempt at understanding what
> is to be done regarding Protocol.WFS and related classes. I looked at it
> from the angle in which it would be useful for me in the case I described
> before.
> * the standard WFS-T
> * Fixed and Save (and perhaps SaveGreedy) strategy
> From I can gather none of these are far from complete, but what I'm missing
> is option to filter the input in Fixed strategy. I noticed that the trunk
> version of BBOX strategy looks for additional filters in the layer and while
> it might be a good place put the additional filter I can't see any
> indication that Layer actually is supposed to support such a property. If it
> should it should be documented and used by fixed strategy also?
> I would like to to implement this before beeing able to do serious testing.
> I nice thing is that I could test stuff directly in a real world case where
> I'm using (successfully) the clumsy old Layer.WFS way with a temp layer. But
> before that I would like to confirm that I got the right idea...
> A question on the side... why are some methods declared "JSONy" i.e 'read'
> instead of read?
> /Björn
> On Wed, Sep 17, 2008 at 2:10 AM, Tim Schaub <tschaub at opengeo.org> wrote:
>> Hey-
>> Björn Harrtell wrote:
>> > Hi devs,
>> > I'm coding an application that uses OL vector editing and WFS
>> > transactions quite heavily.
>> > I use a temporary OpenLayers.Layer.Vector for editing, moving stuff to a
>> > OpenLayers.Layer.WFS as the user makes edits. This is a bit clumsy and
>> > complicated but works. The reason why I'm doing this is because
>> > OpenLayers.Layer.WFS only supports GET and is also loading features on
>> > demand (hmm is this correct?) which doesn't fit my needs. Note that I do
>> > not add the OpenLayers.Layer.WFS to a map, I only use create/commit the
>> > WFS transactions.
>> > I would like to use something like a static/manually triggered WFS
>> > (supporting POST and filtering) source to an OpenLayers.Layer.Vector
>> > that syncs changes to the WFS source which then can be commited
>> > programmatically.
>> > Is this sort of what OpenLayers.Protocol.WFS (which I think is beeing
>> > worked on?) is supposed to be used for? Or would it be sensible to make
>> > something more of OpenLayers.Layer.WFS instead?
>> Yes, this is exactly the job for a WFS protocol. As Eric mentions, the
>> work is mostly in the vector-behavior sandbox. I'll make an effort to
>> update that and to get a patch ready for the trunk.
>> My hope is to get the WFS protocol in the trunk before the end of next
>> week. Any help you can contribute would be appreciated.
>> Watch the WFS protocol ticket [1] for updates from me, and leave any
>> comments/patches there that you put together.
>> Tim
>> [1] http://trac.openlayers.org/ticket/1648
>> > Either way, I'm interested in (trying) to help out if this seems like
>> > something you would like to support in OL, and can probably do it as a
>> > part of the current project as it would simplify things for me I think.
>> > Regards,
>> > Björn Harrtell
>> > GIS Consultant
>> > SWECO Position AB
>> > <http://www.swecogroup.com/en/Sweco-group/Services/Geographic-IT/>
>> > _______________________________________________
>> > Dev mailing list
>> > Dev at openlayers.org
>> > http://openlayers.org/mailman/listinfo/dev
>> Tim Schaub
>> OpenGeo - http://opengeo.org
>> Expert service straight from the developers.
>> Dev mailing list
More information about the Dev
