[OpenLayers-Dev] Development regarding WFS layer/protocol
Tim Schaub tschaub at opengeo.org
Tue Sep 23 14:40:54 EDT 2008
Hey-
I put up a patch that represents progress towards a working WFS protocol.
http://trac.openlayers.org/ticket/1648
I'll work on it a bit more tomorrow.  Please feel free to pick it up and
push it forward (anyone).  The wfs-protocol-transactions.html example is
a good place to start with a debugger.  In the end, this example will do
inserts, updates, and deletes (with a commit from the save button).
Tim
Björn Harrtell wrote:
> I have been making a serious (relatively? :) attempt at understanding
> what is to be done regarding Protocol.WFS and related classes. I looked
> at it from the angle in which it would be useful for me in the case I
> described before.
> * the standard WFS-T
> * Fixed and Save (and perhaps SaveGreedy) strategy
>  From I can gather none of these are far from complete, but what I'm
> missing is option to filter the input in Fixed strategy. I noticed that
> the trunk version of BBOX strategy looks for additional filters in the
> layer and while it might be a good place put the additional filter I
> can't see any indication that Layer actually is supposed to support such
> a property. If it should it should be documented and used by fixed
> strategy also?
> I would like to to implement this before beeing able to do serious
> testing. I nice thing is that I could test stuff directly in a real
> world case where I'm using (successfully) the clumsy old Layer.WFS way
> with a temp layer. But before that I would like to confirm that I got
> the right idea...
> A question on the side... why are some methods declared "JSONy" i.e
> 'read' instead of read?
> /Björn
> On Wed, Sep 17, 2008 at 2:10 AM, Tim Schaub <tschaub at opengeo.org
> <mailto:tschaub at opengeo.org>> wrote:
>     Hey-
>      > Hi devs,
>      > I'm coding an application that uses OL vector editing and WFS
>      > transactions quite heavily.
>      > I use a temporary OpenLayers.Layer.Vector for editing, moving
>     stuff to a
>      > OpenLayers.Layer.WFS as the user makes edits. This is a bit
>     clumsy and
>      > complicated but works. The reason why I'm doing this is because
>      > OpenLayers.Layer.WFS only supports GET and is also loading
>     features on
>      > demand (hmm is this correct?) which doesn't fit my needs. Note
>     that I do
>      > not add the OpenLayers.Layer.WFS to a map, I only use
>     create/commit the
>      > WFS transactions.
>      > I would like to use something like a static/manually triggered WFS
>      > (supporting POST and filtering) source to an OpenLayers.Layer.Vector
>      > that syncs changes to the WFS source which then can be commited
>      > programmatically.
>      > Is this sort of what OpenLayers.Protocol.WFS (which I think is beeing
>      > worked on?) is supposed to be used for? Or would it be sensible
>     to make
>      > something more of OpenLayers.Layer.WFS instead?
>     Yes, this is exactly the job for a WFS protocol.  As Eric mentions, the
>     work is mostly in the vector-behavior sandbox.  I'll make an effort to
>     update that and to get a patch ready for the trunk.
>     My hope is to get the WFS protocol in the trunk before the end of next
>     week.  Any help you can contribute would be appreciated.
>     Watch the WFS protocol ticket [1] for updates from me, and leave any
>     comments/patches there that you put together.
>     Tim
>     [1] http://trac.openlayers.org/ticket/1648
>      > Either way, I'm interested in (trying) to help out if this seems like
>      > something you would like to support in OL, and can probably do it
>     as a
>      > part of the current project as it would simplify things for me I
>     think.
>      > Regards,
>      > Björn Harrtell
>      > GIS Consultant
>      > SWECO Position AB
>      > <http://www.swecogroup.com/en/Sweco-group/Services/Geographic-IT/>
>      > _______________________________________________
>      > Dev mailing list
>      > Dev at openlayers.org <mailto:Dev at openlayers.org>
>      > http://openlayers.org/mailman/listinfo/dev
>     Tim Schaub
>     OpenGeo - http://opengeo.org
>     Expert service straight from the developers.
>     Dev mailing list
Tim Schaub
More information about the Dev mailing list
