[OpenLayers-Dev] Development regarding WFS layer/protocol
Tim Schaub
tschaub at opengeo.org
Tue Sep 23 19:46:15 EDT 2008
Hey-
So, tests are now passing with the WFS protocol. I think this is pretty
close and would appreciate any help creating tests, trying it out, etc.
The patch [1] includes a very basic Save strategy. This is a manual
save strategy (requires that you call save). It can be used as the
basis for auto or greedy save strategies, but I think we should keep it
simple for this patch.
Thanks for any assistance testing/reviewing.
Tim
[1] http://trac.openlayers.org/ticket/1648
Tim Schaub wrote:
> Hey-
> I put up a patch that represents progress towards a working WFS protocol.
> I'll work on it a bit more tomorrow. Please feel free to pick it up and
> push it forward (anyone). The wfs-protocol-transactions.html example is
> a good place to start with a debugger. In the end, this example will do
> inserts, updates, and deletes (with a commit from the save button).
> Tim
> Björn Harrtell wrote:
>> I have been making a serious (relatively? :) attempt at understanding
>> what is to be done regarding Protocol.WFS and related classes. I looked
>> at it from the angle in which it would be useful for me in the case I
>> described before.
>> * the standard WFS-T
>> * Fixed and Save (and perhaps SaveGreedy) strategy
>> From I can gather none of these are far from complete, but what I'm
>> missing is option to filter the input in Fixed strategy. I noticed that
>> the trunk version of BBOX strategy looks for additional filters in the
>> layer and while it might be a good place put the additional filter I
>> can't see any indication that Layer actually is supposed to support such
>> a property. If it should it should be documented and used by fixed
>> strategy also?
>> I would like to to implement this before beeing able to do serious
>> testing. I nice thing is that I could test stuff directly in a real
>> world case where I'm using (successfully) the clumsy old Layer.WFS way
>> with a temp layer. But before that I would like to confirm that I got
>> the right idea...
>> A question on the side... why are some methods declared "JSONy" i.e
>> 'read' instead of read?
>> /Björn
>> On Wed, Sep 17, 2008 at 2:10 AM, Tim Schaub <tschaub at opengeo.org
>> <mailto:tschaub at opengeo.org>> wrote:
>> Hey-
>> > Hi devs,
>> > I'm coding an application that uses OL vector editing and WFS
>> > transactions quite heavily.
>> > I use a temporary OpenLayers.Layer.Vector for editing, moving
>> stuff to a
>> > OpenLayers.Layer.WFS as the user makes edits. This is a bit
>> clumsy and
>> > complicated but works. The reason why I'm doing this is because
>> > OpenLayers.Layer.WFS only supports GET and is also loading
>> features on
>> > demand (hmm is this correct?) which doesn't fit my needs. Note
>> that I do
>> > not add the OpenLayers.Layer.WFS to a map, I only use
>> create/commit the
>> > WFS transactions.
>> > I would like to use something like a static/manually triggered WFS
>> > (supporting POST and filtering) source to an OpenLayers.Layer.Vector
>> > that syncs changes to the WFS source which then can be commited
>> > programmatically.
>> > Is this sort of what OpenLayers.Protocol.WFS (which I think is beeing
>> > worked on?) is supposed to be used for? Or would it be sensible
>> to make
>> > something more of OpenLayers.Layer.WFS instead?
>> Yes, this is exactly the job for a WFS protocol. As Eric mentions, the
>> work is mostly in the vector-behavior sandbox. I'll make an effort to
>> update that and to get a patch ready for the trunk.
>> My hope is to get the WFS protocol in the trunk before the end of next
>> week. Any help you can contribute would be appreciated.
>> Watch the WFS protocol ticket [1] for updates from me, and leave any
>> comments/patches there that you put together.
>> Tim
>> > Either way, I'm interested in (trying) to help out if this seems like
>> > something you would like to support in OL, and can probably do it
>> as a
>> > part of the current project as it would simplify things for me I
>> think.
>> > Regards,
>> > Björn Harrtell
>> > GIS Consultant
>> > SWECO Position AB
>> > <http://www.swecogroup.com/en/Sweco-group/Services/Geographic-IT/>
>> > _______________________________________________
>> > Dev mailing list
>> > Dev at openlayers.org <mailto:Dev at openlayers.org>
>> > http://openlayers.org/mailman/listinfo/dev
>> Tim Schaub
>> OpenGeo - http://opengeo.org
>> Expert service straight from the developers.
>> Dev mailing list
Tim Schaub
More information about the Dev
