[OpenLayers-Dev] How to display shapefile?
rldhont rldhont at gmail.com
Tue Apr 14 10:19:57 EDT 2009
You could use ogr2ogr form GDAL/OGR
Kwong Hu Kiu a écrit :
> Thanks for the quick reply.
> How should i do that ? Do i have to use a program to regenerate the
> shapefile into those format ?
> Any link ?
> Cheers
> > Date: Tue, 14 Apr 2009 16:16:22 +0200
> > From: rldhont at gmail.com
> > To: kwonghu at hotmail.com
> > CC: dev at openlayers.org
> > Subject: Re: [OpenLayers-Dev] How to display shapefile?
> > You have to change the format : GML, JSON, KML
> > Because OpenLayers is a JavaScript library, it's limited by the
> > navigator capabilities and a navigator isn't capable to read ESRI
> > ShapeFile.
> > > Hi all,
> > > May i know how i can display shapefile using openlayers ?
> > > Shapefile works with ESRI. How can i include it in openlayers ?
> > > Any code example around ?
> > > Cheers.
> > > _______________________________________________
> > > Dev mailing list
> > > Dev at openlayers.org
> > > http://openlayers.org/mailman/listinfo/dev
More information about the Dev mailing list
