[OpenLayers-Dev] ERROR:OpenLayers.Protocol.WFS is undefined
Tim Schaub
tschaub at opengeo.org
Fri Apr 17 14:57:46 EDT 2009
prageeth kapuruge wrote:
> when i try to use OpenLayers.Protocol.WFS in my application,it says that
> OpenLayers.Protocol.WFS is undefined,the reason is WFS.js file is not
> available in the OpenLayers-2.7\lib\OpenLayers\Protocol folder,i wanna
> know the release which has WFS.js in the
> OpenLayers-2.7\lib\OpenLayers\Protocol folder,so that i can use
> OpenLayers.Protocol.WFS in my programme.
> i can't see OpenLayers.Protocol.WFS in the documentation also.which is
> http://dev.openlayers.org/releases/OpenLayers-2.7/doc/apidocs/files/OpenLayers-js.html.
> can any one please help me to find the version which has
> OpenLayers.Protocol.WFS,please send me the link where i can download it..
> thanks in advance!!!
If you'd like to browse what is available in various releases, the API
docs link you provide above is a good way to go - with the following
being a suitable index:
If you'd like to browse what is available in various releases by looking
at the code, you can start from the following:
http://trac.openlayers.org/browser/tags/openlayers
If you'd like to see what is available in the trunk (under current
development), find the following:
http://dev.openlayers.org/apidocs/files/OpenLayers-js.html
(linked from http://trac.openlayers.org/wiki/Documentation)
If you'd like the code from the trunk (subject to change, may not be
suitable for production), read the following:
http://trac.openlayers.org/wiki/HowToDownload
(linked from http://trac.openlayers.org/)
Tim
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
Tim Schaub
OpenGeo - http://opengeo.org
Expert service straight from the developers.
More information about the Dev
