[OpenLayers-Dev] vector label orientation
Christopher Schmidt crschmidt at metacarta.com
Fri Apr 17 19:09:24 EDT 2009
On Fri, Apr 17, 2009 at 09:44:35PM +0100, John McCrae wrote:
> Hello
> Is there a way to orientate a text label based on a vector <name> tag or similar so that it follows the direction of a path. For example a road running at a 45 degree angle with a text label offset but also at the same 45 degree angle
No, I don't believe so.
Regards,
Christopher Schmidt
MetaCarta
More information about the Dev mailing list
