[OpenLayers-Dev] vector label orientation
John McCrae johnmccraejnr at hotmail.com
Fri Apr 17 16:44:35 EDT 2009
Hello
Is there a way to orientate a text label based on a vector <name> tag or similar so that it follows the direction of a path. For example a road running at a 45 degree angle with a text label offset but also at the same 45 degree angle
Thank you
_________________________________________________________________
Beyond Hotmail — see what else you can do with Windows Live.
http://clk.atdmt.com/UKM/go/134665375/direct/01/
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20090417/63610a46/attachment.html
More information about the Dev mailing list
