[OpenLayers-Dev] Select Feature - programatically select - doesn't check if feature is already selected
Ivan Grcic ivan.grcic at geofoto.hr
Thu Aug 6 05:41:51 EDT 2009
If we do several times:
selectContorl.select(feature)
feature is added to layer.selectedFeature array several times.
Should we first check  if the feature is allready selected (ill open a ticket)
if (OpenLayers.Util.indexOf(layer.selectedFeatures, feature) == -1) {
    this.select(feature);
Or we leave selectControl as it is, and leave this to user to solve it
on application level?
Regards
Ivan Grcic
More information about the Dev mailing list
