[OpenLayers-Dev] Select Feature - programatically select -
doesn't check if feature is already selected
Alexandre Dube
adube at mapgears.com
Thu Aug 6 08:30:26 EDT 2009
Hi Ivan,
Do you have an example showing when this can happen ? I've been playing
with the SelectFeature control and can't figure how you can have the
same feature added 2 times to the layer.selectedFeatures array, unless
you do it manually.
Regards,
Alexandre
Ivan Grcic wrote:
> If we do several times:
> selectContorl.select(feature)
> feature is added to layer.selectedFeature array several times.
> Should we first check if the feature is allready selected (ill open a ticket)
> if (OpenLayers.Util.indexOf(layer.selectedFeatures, feature) == -1) {
> this.select(feature);
> Or we leave selectControl as it is, and leave this to user to solve it
> on application level?
> Regards
Alexandre Dubé
Mapgears
www.mapgears.com
More information about the Dev
