[OpenLayers-Dev] Select Feature - programatically select - doesn't check if feature is already selected
Ivan Grcic ivan.grcic at geofoto.hr
Thu Aug 6 09:49:02 EDT 2009
Yep, im calling select manually (programatically)
On Thu, Aug 6, 2009 at 2:30 PM, Alexandre Dube<adube at mapgears.com> wrote:
> Hi Ivan,
> Do you have an example showing when this can happen ? I've been playing with
> the SelectFeature control and can't figure how you can have the same feature
> added 2 times to the layer.selectedFeatures array, unless you do it
> manually.
> Regards,
> Alexandre
> Ivan Grcic wrote:
>> If we do several times:
>> selectContorl.select(feature)
>> feature is added to layer.selectedFeature array several times.
>> Should we first check  if the feature is allready selected (ill open a
>> ticket)
>> if (OpenLayers.Util.indexOf(layer.selectedFeatures, feature) == -1) {
>>    this.select(feature);
>> Or we leave selectControl as it is, and leave this to user to solve it
>> on application level?
>> Regards
> Alexandre Dubé
> Mapgears
> www.mapgears.com
Ivan Grcic
More information about the Dev mailing list
