[OpenLayers-Dev] zindex of vertices in ModifyFeature control
Paul Spencer pspencer at dmsolutions.ca
Fri Aug 21 18:00:03 EDT 2009
And of course I found the answer directly after my question, I can set
modifyControl.virtualStyle.graphicZIndex = 10 to put the virtual
points above my features.
Is this a bug in the modify control, i.e. should it check the
graphicZIndex of the selected feature and adjust the virtualStyle
accordingly so the edit controls appear on top?
Cheers
Paul
On 21-Aug-09, at 5:53 PM, Paul Spencer wrote:
> Hi,
> I'm using the ModifyFeature control and have an issue where the small
> circles that are used to modify a polygon or line are 'under' the
> feature itself which results in parts of the circles not being
> available for click/drag.
> I am using a custom style map for my features which is used for
> default and selected styles.  The style defines a graphicZIndex for
> points of 8, for lines 4 and for polygons 2 which I thought might put
> the editing points on top.
> Any ideas?
> Cheers
> Paul
> __________________________________________
>    Paul Spencer
>    Chief Technology Officer
>    DM Solutions Group Inc
>    http://research.dmsolutions.ca/
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
    Paul Spencer
More information about the Dev mailing list
