[OpenLayers-Dev] pink examples
Tim Schaub
tschaub at opengeo.org
Mon Aug 24 16:32:35 EDT 2009
Hey-
Regarding http://trac.openlayers.org/changeset/9630, I removed the
http://www2.dmsolutions.ca/cgi-bin/mswms_gmap reference because I
couldn't find an alternative (in a few minutes of poking around).
I only made the change on that one example because it is the default one
that shows up for http://openlayers.org/dev/examples/. There are other
examples that use the same WMS. If the resource has moved, please
update the other examples with the correct URL.
I'll keep poking around for an alternative.
Tim
Tim Schaub
OpenGeo - http://opengeo.org
Expert service straight from the developers.
More information about the Dev
