[OpenLayers-Dev] [jonathan.pasquier@gmail.com: Re: OpenLayers & SVG Web]
Christopher Schmidt crschmidt at metacarta.com
Wed Dec 2 09:21:01 EST 2009
----- Forwarded message from Jonathan Pasquier <jonathan.pasquier at gmail.com> -----
From: Jonathan Pasquier <jonathan.pasquier at gmail.com>
To: Christopher Schmidt <crschmidt at metacarta.com>
Date: Wed, 2 Dec 2009 00:11:09 +0100
Subject: Re: [OpenLayers-Dev] OpenLayers & SVG Web
Hello Chris,
I know that OpenLayers has support for vector drawing in all the browsers,
I have used a lot this feature and it's working really well.
What I wanted to do was just to experiment with SVG Web as well as get an
insight on the internals of OpenLayers.
As you can see on my webpage, the port of svg web to openlayers is not
really usable at the moment (missing features + speed issue).
I know that introducing a dependency upon an external library is not really
great, but it could be nice to have a full SVG support across all browsers.
This could allow us to use specific SVG features (SMIL, filters, etc..) or
to use SVG art on openlayers maps.
What do you think about it?
Regards,
Jonathan
2009/11/30 Christopher Schmidt <crschmidt at metacarta.com>
> On Fri, Nov 27, 2009 at 03:06:24PM +0100, Jonathan Pasquier wrote:
> > Hello,
> > I have been doing some experiment with OpenLayers recently, and
> especially
> > with the Vector feature.
> > After seeing the recent announcement of a new release of SVG
> > web<http://code.google.com/p/svgweb/>,
> > a js library which aims to provide suport for SVG to all browser,
> > I have decided to try to integrate it with OpenLayers so I could use my
> > beloved SVG under any browser (including IE!!!)
> OpenLayers already has support for vectors in all browsers, including IE.
> No use of an external library is neccesary.
> What were you trying to accomplish using svgweb?
> -- Chris
> > After a couple of days fighting against the DOM, javascript and flash, I
> > have finally manage to get something usable.
> > It still in alpha stage, but if you want you can give it a try.
> > Source and examples are available here:
> > http://www.bordel-de-nerd.net/olsvgweb/
> > I have only tested it under Firefox 3.5 and IE 8, but it should work with
> > other browsers as well.
> > Any comment or suggestion will be welcome!
> > Regards,
> > Jonathan
> > Dev mailing list
> > Dev at openlayers.org
> > http://openlayers.org/mailman/listinfo/dev
> Christopher Schmidt
> MetaCarta
----- End forwarded message -----
Christopher Schmidt
MetaCarta
More information about the Dev mailing list
