[OpenLayers-Dev] GML parser and attribute nodes
Tim Schaub tschaub at opengeo.org
Wed Feb 4 11:53:27 EST 2009
Hey-
bartvde at osgis.nl wrote:
> Typo in my post, the last one should be _geometry, so:
>                     if(node.childNodes.length == 1 &&
> node.firstChild.nodeType == 3) {
>                         if(this.extractAttributes) {
>                             name = "_attribute";
>                     } else if (node.childNodes.length == 0) {
>                     } else {
>                         name = "_geometry";
Yeah, I like the look of that better :).
I think this sounds good.  Please open a ticket.
Tim
>> Hi list,
>> currently the GML/Base.js parser ignores attribute nodes like:
>> <rws:ELEMENTCODE></rws:ELEMENTCODE>
>> This is because of the following check:
>> if(node.childNodes.length == 1 && node.firstChild.nodeType == 3) {
>> However, I would like to parse this type of attribute node (because
>> otherwise I will have to protect all code that does something with the
>> features against this case, e.g. JSON encoding the features and exporting
>> them to Excel results in a shifting columns problem), so I've modified
>> Base.js in the following way:
>>                     } else {
>> Is this something general, or very specific to my use-case? Should I open
>> up a ticket with a patch?
>> Best regards,
>> Bart
>> Dev mailing list
>> Dev at openlayers.org
>> http://openlayers.org/mailman/listinfo/dev
> Dev mailing list
Tim Schaub
OpenGeo - http://opengeo.org
Expert service straight from the developers.
More information about the Dev mailing list
