[OpenLayers-Dev] GML parser and attribute nodes
Christopher Schmidt
crschmidt at metacarta.com
Wed Feb 4 11:54:33 EST 2009
On Wed, Feb 04, 2009 at 09:53:27AM -0700, Tim Schaub wrote:
> Hey-
> bartvde at osgis.nl wrote:
> > Typo in my post, the last one should be _geometry, so:
> > if(node.childNodes.length == 1 &&
> > node.firstChild.nodeType == 3) {
> > if(this.extractAttributes) {
> > name = "_attribute";
> > } else if (node.childNodes.length == 0) {
> > } else {
> > name = "_geometry";
> Yeah, I like the look of that better :).
> I think this sounds good. Please open a ticket.
http://trac.openlayers.org/ticket/1927
> Tim
> >> Hi list,
> >> currently the GML/Base.js parser ignores attribute nodes like:
> >> <rws:ELEMENTCODE></rws:ELEMENTCODE>
> >> This is because of the following check:
> >> if(node.childNodes.length == 1 && node.firstChild.nodeType == 3) {
> >> However, I would like to parse this type of attribute node (because
> >> otherwise I will have to protect all code that does something with the
> >> features against this case, e.g. JSON encoding the features and exporting
> >> them to Excel results in a shifting columns problem), so I've modified
> >> Base.js in the following way:
> >> } else {
> >> Is this something general, or very specific to my use-case? Should I open
> >> up a ticket with a patch?
> >> Best regards,
> >> Bart
> >> _______________________________________________
> >> Dev mailing list
> >> Dev at openlayers.org
> >> http://openlayers.org/mailman/listinfo/dev
> > Dev mailing list
> Tim Schaub
> OpenGeo - http://opengeo.org
> Expert service straight from the developers.
> Dev mailing list
Christopher Schmidt
MetaCarta
More information about the Dev
