[OpenLayers-Dev] GML parser and attribute nodes
Tim Schaub
tschaub at opengeo.org
Wed Feb 4 12:28:48 EST 2009
Hey-
Christopher Schmidt wrote:
> On Wed, Feb 04, 2009 at 09:53:27AM -0700, Tim Schaub wrote:
>> Hey-
>> bartvde at osgis.nl wrote:
>>> Typo in my post, the last one should be _geometry, so:
>>> if(node.childNodes.length == 1 &&
>>> node.firstChild.nodeType == 3) {
>>> if(this.extractAttributes) {
>>> name = "_attribute";
>>> } else if (node.childNodes.length == 0) {
>>> } else {
>>> name = "_geometry";
>> Yeah, I like the look of that better :).
>> I think this sounds good. Please open a ticket.
> http://trac.openlayers.org/ticket/1927
Bart, I added some tests. If someone runs them in IE, I'll commit.
Also, if you can't provide a test with a patch, at least some sample
data helps. I get tired of making up GML all the time.
Tim
>> Tim
>>>> Hi list,
>>>> currently the GML/Base.js parser ignores attribute nodes like:
>>>> <rws:ELEMENTCODE></rws:ELEMENTCODE>
>>>> This is because of the following check:
>>>> if(node.childNodes.length == 1 && node.firstChild.nodeType == 3) {
>>>> However, I would like to parse this type of attribute node (because
>>>> otherwise I will have to protect all code that does something with the
>>>> features against this case, e.g. JSON encoding the features and exporting
>>>> them to Excel results in a shifting columns problem), so I've modified
>>>> Base.js in the following way:
>>>> } else {
>>>> Is this something general, or very specific to my use-case? Should I open
>>>> up a ticket with a patch?
>>>> Best regards,
>>>> Bart
>>>> _______________________________________________
>>>> Dev mailing list
>>>> Dev at openlayers.org
>>>> http://openlayers.org/mailman/listinfo/dev
>>> Dev mailing list
>> Tim Schaub
>> OpenGeo - http://opengeo.org
>> Expert service straight from the developers.
>> Dev mailing list
Tim Schaub
More information about the Dev
