[OpenLayers-Dev] GML parser and attribute nodes
Bart van den Eijnden (OSGIS)
bartvde at osgis.nl
Wed Feb 4 13:10:51 EST 2009
Hey Tim,
sorry for not providing a test case, it just slipped my mind in this
case. I was also trying to see if there was interest before going to the
trouble, so you've beat me to it in a way. Thanks.
I've just run tests before and after applying the patch in IE7, and can
confirm things work okay, except the usual suspect overview map failing
1 test, but there is an open ticket for that already.
Thanks again.
Best regards,
Bart
Tim Schaub wrote:
> Hey-
> Christopher Schmidt wrote:
>> On Wed, Feb 04, 2009 at 09:53:27AM -0700, Tim Schaub wrote:
>>> Hey-
>>> bartvde at osgis.nl wrote:
>>>> Typo in my post, the last one should be _geometry, so:
>>>> if(node.childNodes.length == 1 &&
>>>> node.firstChild.nodeType == 3) {
>>>> if(this.extractAttributes) {
>>>> name = "_attribute";
>>>> } else if (node.childNodes.length == 0) {
>>>> } else {
>>>> name = "_geometry";
>>> Yeah, I like the look of that better :).
>>> I think this sounds good. Please open a ticket.
>> http://trac.openlayers.org/ticket/1927
> Bart, I added some tests. If someone runs them in IE, I'll commit.
> Also, if you can't provide a test with a patch, at least some sample
> data helps. I get tired of making up GML all the time.
> Tim
>>> Tim
>>>>> Hi list,
>>>>> currently the GML/Base.js parser ignores attribute nodes like:
>>>>> <rws:ELEMENTCODE></rws:ELEMENTCODE>
>>>>> This is because of the following check:
>>>>> if(node.childNodes.length == 1 && node.firstChild.nodeType == 3) {
>>>>> However, I would like to parse this type of attribute node (because
>>>>> otherwise I will have to protect all code that does something with the
>>>>> features against this case, e.g. JSON encoding the features and exporting
>>>>> them to Excel results in a shifting columns problem), so I've modified
>>>>> Base.js in the following way:
>>>>> } else {
>>>>> Is this something general, or very specific to my use-case? Should I open
>>>>> up a ticket with a patch?
>>>>> Best regards,
>>>>> Bart
>>>>> _______________________________________________
>>>>> Dev mailing list
>>>>> Dev at openlayers.org
>>>>> http://openlayers.org/mailman/listinfo/dev
>>>> Dev mailing list
>>> Tim Schaub
>>> OpenGeo - http://opengeo.org
>>> Expert service straight from the developers.
>>> Dev mailing list
OSGIS, Open Source GIS
bartvde at osgis.nl
http://www.osgis.nl
More information about the Dev
