[OpenLayers-Dev] GML parser and attribute nodes
Tim Schaub
tschaub at opengeo.org
Wed Feb 4 13:34:36 EST 2009
Hey-
Bart van den Eijnden (OSGIS) wrote:
> Hey Tim,
> sorry for not providing a test case, it just slipped my mind in this
> case. I was also trying to see if there was interest before going to the
> trouble, so you've beat me to it in a way. Thanks.
No problem. Thanks for the patch. I just need a vacation after too
much test writing.
> I've just run tests before and after applying the patch in IE7, and can
> confirm things work okay, except the usual suspect overview map failing
> 1 test, but there is an open ticket for that already.
> Thanks again.
> Best regards,
> Bart
> Tim Schaub wrote:
>> Hey-
>> Christopher Schmidt wrote:
>>> On Wed, Feb 04, 2009 at 09:53:27AM -0700, Tim Schaub wrote:
>>>> Hey-
>>>> bartvde at osgis.nl wrote:
>>>>> Typo in my post, the last one should be _geometry, so:
>>>>> if(node.childNodes.length == 1 &&
>>>>> node.firstChild.nodeType == 3) {
>>>>> if(this.extractAttributes) {
>>>>> name = "_attribute";
>>>>> } else if (node.childNodes.length == 0) {
>>>>> } else {
>>>>> name = "_geometry";
>>>> Yeah, I like the look of that better :).
>>>> I think this sounds good. Please open a ticket.
>>> http://trac.openlayers.org/ticket/1927
>> Bart, I added some tests. If someone runs them in IE, I'll commit.
>> Also, if you can't provide a test with a patch, at least some sample
>> data helps. I get tired of making up GML all the time.
>> Tim
>>>> Tim
>>>>>> Hi list,
>>>>>> currently the GML/Base.js parser ignores attribute nodes like:
>>>>>> <rws:ELEMENTCODE></rws:ELEMENTCODE>
>>>>>> This is because of the following check:
>>>>>> if(node.childNodes.length == 1 && node.firstChild.nodeType == 3) {
>>>>>> However, I would like to parse this type of attribute node (because
>>>>>> otherwise I will have to protect all code that does something with
>>>>>> the
>>>>>> features against this case, e.g. JSON encoding the features and
>>>>>> exporting
>>>>>> them to Excel results in a shifting columns problem), so I've
>>>>>> modified
>>>>>> Base.js in the following way:
>>>>>> } else {
>>>>>> Is this something general, or very specific to my use-case? Should
>>>>>> I open
>>>>>> up a ticket with a patch?
>>>>>> Best regards,
>>>>>> Bart
>>>>>> _______________________________________________
>>>>>> Dev mailing list
>>>>>> Dev at openlayers.org
>>>>>> http://openlayers.org/mailman/listinfo/dev
>>>>> Dev mailing list
>>>> Tim Schaub
>>>> OpenGeo - http://opengeo.org
>>>> Expert service straight from the developers.
>>>> Dev mailing list
Tim Schaub
More information about the Dev
