[OpenLayers-Dev] new doc for OpenLayers
Yves Jacolin (free)
yjacolin at free.fr
Wed Feb 4 16:15:17 EST 2009
Hi Christopher,
Sorry for the long time to post an answer, I was quiet busy in january.
After reading your three emails and thought about those, I think I would help
better the project if I am working on a french translation of the
documentation.
I read again some of your older email and you said to me to wait a little bit
before begining a translation. As OSGeo-fr began the translation of the QGIS
documentation, I will wait that we finish it or starts it when I will have
some time to spend.
To give more information about the "introdcution", the filename is wrong, I
have to give a name to the file and the document and give it this one. This
is not an "introduction" of a book or for a full documentation, but an
introduction for french people to beging to work with OpenLayers with their
data and google map as a baselayer. Mainly because in some french forum, a
lot of question were asked about this. And indeed, it tends to wander a
bit.
So if developers agreed, I will work on the french translation as soon as you
told me how to send the translated files and how to follow changes in the
original documentations, (ie if possible to get an email if someone changed
the file in svn).
Best regards,
Y.
Le mercredi 31 décembre 2008, Christopher Schmidt a écrit :
> On Wed, Dec 31, 2008 at 03:34:08PM +0100, Jacolin wrote:
> > Hi dev list,
> > Here is a rst file for an introduction about OpenLayers. All informations
> > may not be correct, nor my english.
> > As you will see, this document could be a duplicate document with the
> > spherical mercator doc ... but less complete.
> I think that we should not have duplicated information; if we need to
> include enough code to make something work, then we can do that, but
> beyond that, we should just link to the spherical mercator doc. (In
> other words, I don't mind having *reasons* for boilerplate code listed
> elsewhere.) I definitely dont think that "How to add 900913 to your Map
> Server" belongs in an intro doc.
> I'm going to clean this up a bit and then we can see what we think about
> it.
> What you have right now is similar to what I have here:
> http://svn.crschmidt.net/personal/openlayers/doc/getting_started.txt
> And I think that's a good start.
> > I would like to know if you (and the community) are interesting to get
> > more document from me, and if others people are working on such document
> > and which topic (in order to avoid other duplicate works).
> > Best regards,
> > Y.
> > Introduction
> > .. contents::
> > Presentation
> > OpenLayers is a library written in JavaScript which allow you to develop
> > easily and quiclky an indepandant map server client interface. It
> > proposes by default loading data from OGC standards like WMS, WFS, from
> > commercial Map Base Layer like Google, Yahoo, Virtual Earth, from various
> > data format KML, GeoRSS, GML, etc. Among features available, you'll find
> > zooming, panning, displaing data, layer tree, tiled layers and cache
> > client side. TileCache allow you to cache server sider and will be
> > presented later in this document.
> > OpenLayers is developed by an increasingly large community, and you can
> > contact them via a mailing list or IRC. OpenLayers is a project hosted by
> > OSGeo. The official site is located at http://openlayers.org.
> > You'll find a short documentation in English here:
> > http://openlayers.org/doc/, the API doc is available here:
> > http://dev.openlayers.org/docs/files/OpenLayers-js. html and there are a
> > lot of examples here: http://openlayers.org/dev/doc/examples.html
> > *Objectifs of this chapter:*
> > * Know more about map and layer object ;
> > * Create your first map ;
> > * Add your own layer using a commercial base layer.
> > Installation
> > There are two ways to use OpenLayers on its Web site. The first is to
> > call the library by the JavaScript <script> tag:
> > .. code-block:: javascript
> > <script src='http://openlayers.org/api/OpenLayers.js'></script>
> > Of course you can download the local library from the download page:
> > http://trac.openlayers.org/wiki/HowToDownload
> > There are two presentations from the library. The first, known as sources
> > of OpenLayers, consists of a file openlayers.js which calls all other
> > files included in the tree of the library. The second version, a version
> > built, but not in binary format, consists of building all the files into
> > a single compressed file. The file size is small, but code is unreadable:
> > any unnecessary space is removed during compression. The call for the
> > library is made by the same way, but with reference to the page where it
> > is called:
> > <script src='api/OpenLayers.js'></script>
> > You are now ready to use the library.
> > My first map
> > The OpenLayers API uses mainly two objects this is not exactly true, but
> > enougth for beginning): the //map// and //layers// objects. A Map object
> > stores information on the map, its size, projection units, its scope, and
> > so on. In a map, the data is displayed in the form of layers
> > (//layers//). A //layers// object is a data source that defines how
> > OpenLayers must recover the data and display them.
> > Setting
> > Building an OpenLayers interface requires the addition of HTML code in
> > your page. You can put a map where you want. Here is a simple example for
> > creating a map with OpenLayers.
> > .. code-block:: html
> > <html>
> > <head>
> > <title>OpenLayers Example</title>
> > <script
> > src="http://openlayers.org/api/OpenLayers.js"></script>
> > </head>
> > <body>
> > <div style="width:100%; height:100%" id="map"></div>
> > </body>
> > </html>
> > To initialize a map in this interface, you must write a few lines of
> > JavaScript code in the header of the page or in a map.js file for
> > example. The file or the code should be placed after the insertion of the
> > library OpenLayers. Generally, it creates a ''init()'' function which,
> > put in the <body> tag initialize the map after loading the page.
> > var map;
> > function init() {
> > //creating map object
> > map = new OpenLayers.Map('map');
> > //creating a WMS layer
> > var wms = new OpenLayers.Layer.WMS(
> > "http://labs.metacarta.com/wms/vmap0",
> > {'layers':'basic'}
> > //adding wms layer to the map object
> > map.addLayer(wms);
> > Here is a full example:
> > <html>
> > <head>
> > <script src="http://openlayers.org/api/OpenLayers.js"></script>
> > </head>
> > <body>
> > <script defer="defer" type="text/javascript">
> > var map = new OpenLayers.Map('map');
> > var wms = new OpenLayers.Layer.WMS( "OpenLayers WMS",
> > "http://labs.metacarta.com/wms/vmap0", {layers: 'basic'} );
> > map.addLayer(wms);
> > map.zoomToMaxExtent();
> > </script>
> > </body>
> > </html>
> > <html>
> > <div style="width:400px; height:200px" id="map"></div>
> > map.addLayer(wms);
> > </script>
> > </html>
> > Add Google Maps Layers
> > Google uses a distorted projection which implies that others layers are
> > not always overlaid correctly. Google uses a Spherical Mercator
> > projection assuming that the earth is spherical (which is incorrect).
> > Following this, for a large zoom a shift appears between the Google map
> > and your data. You can reproject your data in another projections (see
> > later), or define the spherial projection within the parameters of the
> > map and set up a parameter in the Commercial base layer options. Here is
> > the way to enable this in your map, first define your map options by
> > using the following:
> > var options = {
> > projection: "EPSG:900913",
> > units: "m",
> > maxResolution: 156543.0339,
> > maxExtent: new OpenLayers.Bounds(-20037508.34,
> > -20037508.34, 20037508.34, 20037508.34) };
> > Projection definition for proj4 is following:
> > .. code-block:: bash
> > +proj=merc +a=6378137 +b=6378137 +lat_ts=0.0 +lon_0=0.0 +x_0=0.0
> > +y_0=0 +k=1.0 +units=m +nadgrids=@null +no_defs
> > More information are available at
> > [[http://proj.maptools.org/faq.html#sphere_as_wgs84|this page]]. For
> > GeoServer:
> > 900913=PROJCS["WGS84 / Simple Mercator", GEOGCS["WGS 84",
> > DATUM["WGS_1984", SPHEROID["WGS_1984", 6378137.0, 298.257223563]],
> > PRIMEM["Greenwich", 0.0], UNIT["degree", 0.017453292519943295],
> > AXIS["Longitude", EAST], AXIS["Latitude", NORTH]],
> > PROJECTION["Mercator_1SP_Google"],
> > PARAMETER["latitude_of_origin", 0.0], PARAMETER["central_meridian",
> > 0.0], PARAMETER["scale_factor", 1.0], PARAMETER["false_easting", 0.0],
> > PARAMETER["false_northing", 0.0], UNIT["m", 1.0], AXIS["x", EAST],
> > AXIS["y", NORTH], AUTHORITY["EPSG","900913"]]
> > The GeoServer release greater or equal to 1.5.4 doesn't need to add the
> > projection definition to the configuration, already included in the
> > configuration file.
> > Go back to OpenLayers, to add a Google base layer you have to add a
> > ''layer'' object to your ''map'' object with the following method:
> > new OpenLayers.Layer.Google(LayerName, options);
> > ''options'' parameter is an array of options to be sent to the method.
> > Available options are (read the OpenLayers API for
> > OpenLayers.Layer.Google to get more information): * ''type'' : type of
> > the commercial base layer, google here (normal, satellite, mixte) ; *
> > ''sphericalMercator'' : is the projection is sphericalMercator? Set value
> > to ''true''.
> > For the ''type'' parameter, choose one between:
> > * G_NORMAL_MAP
> > * G_SATELLITE_MAP
> > * G_HYBRID_MAP
> > You have three constants that you can modify:
> > * ''MIN_ZOOM_LEVEL'' : default value: 0 ;
> > * ''MAX_ZOOM_LEVEL'' : default value: 19 ;
> > * ''RESOLUTIONS''
> > For example:
> > var google = new OpenLayers.Layer.Google(
> > "Google Streets",
> > {type: G_NORMAL_MAP, 'sphericalMercator': true}
> > .. important::
> > If you enable several type of Google layer (hybrid, default, satellite,
> > for example), add your layers with the ''addlayers()'' method or you can
> > have a shift between each Google baselayer. Example: ''map.addLayers
> > ([google, hybrid, satellite]);''
> > If you wish to overlay a GML layer (or other) with a commecial baselayer
> > (like Google), you *must* use the option '' 'sphericalMercator': true'',
> > moreover you have to reproject your data in the correct projection, like
> > this:
> > ogr2ogr -f "ESRI Shapefile" -t_srs "+proj=merc +a=6378137 +b=6378137
> > +lat_ts=0.0 +lon_0=0.0 +x_0=0.0 +y_0=0 +k=1.0 +units=m +nadgrids=@null
> > +no_defs" -s_srs "EPSG:4326" Mono2006_2.shp Mono2006_region.shp
> > If you are using OGR release greater or equal to 1.5.0, use the
> > 'EPSG:900913' code directly to reproject your data.
> > Finally, for PostGIS this can be useful:
> > .. code-block:: sql
> > INSERT INTO spatial_ref_sys (srid,auth_name,auth_srid,srtext,proj4text)
> > VALUES (900913,'EPSG',900913,'PROJCS["Google Mercator", GEOGCS["WGS
> > 84",DATUM["World Geodetic System 1984", SPHEROID["WGS 84", 6378137.0,
> > 298.257223563,
> > AUTHORITY["EPSG","7030"]],AUTHORITY["EPSG","6326"]],PRIMEM["Greenwich",
> > 0.0, AUTHORITY["EPSG","8901"]], UNIT["degree", 0.017453292519943295],
> > AXIS["Geodetic latitude", NORTH], AXIS["Geodetic longitude", EAST],
> > AUTHORITY["EPSG","4326"]], PROJECTION["Mercator (1SP)",
> > AUTHORITY["EPSG","9804"]], PARAMETER["semi_major", 6378137.0],
> > PARAMETER["semi_minor", 6378137.0], PARAMETER["latitude_of_origin", 0.0],
> > PARAMETER["central_meridian", 0.0], PARAMETER["scale_factor", 1.0],
> > PARAMETER["false_easting", 0.0], PARAMETER["false_northing", 0.0],
> > UNIT["m", 1.0], AXIS["Easting", EAST], AXIS["Northing", NORTH],
> > AUTHORITY["EPSG","900913"]]','+proj=merc +a=6378137 +b=6378137
> > +no_defs');
> > *Get more information:*
> > * spherical_mercator.rst
> > * http://www.nabble.com/sphericalMercator-tf4625750.html#a13209474
> > http://dev.openlayers.org/docs/files/OpenLayers/Layer/SphericalMercator-j
> >s.html * http://trac.osgeo.org/gdal/ticket/1868: adding EPSG:900913 code
> > to your EPSG file.
> > --- //[[yjacolin at free.fr|Yves Jacolin]] 2008/07/17 21:45//
> > Dev mailing list
> > Dev at openlayers.org
> > http://openlayers.org/mailman/listinfo/dev
Yves Jacolin
"Donner la liberté aux individus ne suffit pas, il faut aussi leur donner du
pouvoir, de la puissance d'agir." M Gauchet
"Give freedom to people is not enough, we also have to give them the power
to use this freedom, to act". M Gauchet
http://yjacolin.gloobe.org
http://softlibre.gloobe.org
More information about the Dev
