[OpenLayers-Dev] Problems parsing gml:boundedBy with
Format.GML.v2
Gorka López Rivacoba
gorka.lopez.rivacoba at gmail.com
Thu Feb 5 05:43:53 EST 2009
Hello,
Thanks for your response, Tim.
>Out of curiosity, why do you want to write gml:boundedBy?
I have an application that read a gml (that contains this label) and edit
the geometries. When I save the file, the file must contain <gml:boundedBy>
label (like the original file)
In this label the SRS is saved, but I don't know if this SRS is used in gml
application readers. Is it used? If not, how does OpenLayers know the
projection of the layer? Does it only depend on the map projection?
Thanks,
Best regards,
Gorka López
2009/2/3 Tim Schaub <tschaub at opengeo.org>
> Hey-
> Gorka López Rivacoba wrote:
> > *Hello,** *
> > *I'm using OpenLayers 2.6, but my problem is the same with OpenLayers
> > 2.7. I load a GML layer in OpenLayers and then I try to serialize it:*
> > var formatter = new OpenLayers.Format.GML.v2({
> > featureType: "demo"});
> > var gml = formatter.write(layerEditable.features);
> > alert(gml);
> > *but in the returned string doesn't appear the gml:boundedBy label. I
> > find ticket#1613 (http://trac.openlayers.org/ticket/1613), but it seems
> > that is only for reading the gml document.** *
> I just made a change to support reading gml:boundedBy (as
> geometry.bounds). I'll update #1613 after making sure the change
> addresses that issue.
> http://trac.openlayers.org/changeset/8808
> > *Is there any solution to write gml:boundedBy label in the final gml?** *
> Nothing currently (though it wouldn't be hard to add your own
> gml:boundedBy writer).
> Tim
> > *Regards,*
> > *Gorka López*
> > Dev mailing list
> > Dev at openlayers.org
> > http://openlayers.org/mailman/listinfo/dev
> Tim Schaub
> OpenGeo - http://opengeo.org
> Expert service straight from the developers.
> Dev mailing list
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20090205/87c69697/attachment.html
More information about the Dev
