[OpenLayers-Dev] Problems parsing gml:boundedBy with
Format.GML.v2
Tim Schaub
tschaub at opengeo.org
Tue Feb 3 16:06:15 EST 2009
Hey-
Tim Schaub wrote:
> Hey-
> Gorka López Rivacoba wrote:
>> *Hello,** *
>> *I'm using OpenLayers 2.6, but my problem is the same with OpenLayers
>> 2.7. I load a GML layer in OpenLayers and then I try to serialize it:*
>> var formatter = new OpenLayers.Format.GML.v2({
>> featureType: "demo"});
>> var gml = formatter.write(layerEditable.features);
>> alert(gml);
>> *but in the returned string doesn't appear the gml:boundedBy label. I
>> find ticket#1613 (http://trac.openlayers.org/ticket/1613), but it seems
>> that is only for reading the gml document.** *
> I just made a change to support reading gml:boundedBy (as
> geometry.bounds). I'll update #1613 after making sure the change
> addresses that issue.
> http://trac.openlayers.org/changeset/8808
The GML 2 and 3 formats now read gml:boundedBy on feature members.
I've closed #1819 and #1613. Open a ticket if you notice any issues.
Tim
>> *Is there any solution to write gml:boundedBy label in the final gml?** *
> Nothing currently (though it wouldn't be hard to add your own
> gml:boundedBy writer).
> Out of curiosity, why do you want to write gml:boundedBy?
> Tim
>> *Regards,*
>> *Gorka López*
>> Dev mailing list
>> Dev at openlayers.org
>> http://openlayers.org/mailman/listinfo/dev
Tim Schaub
OpenGeo - http://opengeo.org
Expert service straight from the developers.
More information about the Dev
