[OpenLayers-Dev] Problems parsing gml:boundedBy with
Format.GML.v2
Tim Schaub
tschaub at opengeo.org
Tue Feb 3 14:55:02 EST 2009
Hey-
Gorka López Rivacoba wrote:
> *Hello,** *
> *I'm using OpenLayers 2.6, but my problem is the same with OpenLayers
> 2.7. I load a GML layer in OpenLayers and then I try to serialize it:*
> var formatter = new OpenLayers.Format.GML.v2({
> featureType: "demo"});
> var gml = formatter.write(layerEditable.features);
> alert(gml);
> *but in the returned string doesn't appear the gml:boundedBy label. I
> find ticket#1613 (http://trac.openlayers.org/ticket/1613), but it seems
> that is only for reading the gml document.** *
I just made a change to support reading gml:boundedBy (as
geometry.bounds). I'll update #1613 after making sure the change
addresses that issue.
http://trac.openlayers.org/changeset/8808
> *Is there any solution to write gml:boundedBy label in the final gml?** *
Nothing currently (though it wouldn't be hard to add your own
gml:boundedBy writer).
Out of curiosity, why do you want to write gml:boundedBy?
Tim
> *Regards,*
> *Gorka López*
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
Tim Schaub
OpenGeo - http://opengeo.org
Expert service straight from the developers.
More information about the Dev
