[OpenLayers-Dev] SRS transform problem EPSG:900913 -> EPSG:23030
Christopher Schmidt
crschmidt at metacarta.com
Fri Feb 20 08:47:06 EST 2009
On Fri, Feb 20, 2009 at 11:50:09AM +0100, Patrick O'Brian wrote:
> Hi all,
> we are using google map layer with WMS from GeoServer using EPSG:23030.
> We have detected a difference between geotools and OpenLayers srs
> conversions using EPSG:900913 -> EPSG:23030.
> Example:
> 900913 => (-754113.99,4563131.15)
> 23030_OpenLayers => (168035.13030878676,4199884.834826067)
> 23030_GeoTools2.5.3 => (168141.88493782945,4199937.868013817)
> which is a huge difference:
> dx=106.75462904269 m
> dy=53.033187750 m
> The WMS image fits with google layer, but the cursor track shows a diferent
> position than the database and the image with the geoserver preview.
> Can anyone tell us which is the correct srs conversion?
Not I, but this is one of two things:
1. a proj4js bug in porting proj
2. A disagreement in the meaning of the spatial reference.
Looking at http://www.spatialreference.org/ref/epsg/23030/ , this is one
of these ED50 projections I hear so much about: As I understand it, thre
are multiple interpretations of ED50 projections depending on where you
are. it seems that OpenLayers and GeoTools are making different default
assumptions.
I think the most likely solution here is that you will need to add a
+towgs84 parameter to the proj4js string. It looks like the default for
23030 in GeoTools is:
TOWGS84[-157.89, -17.16, -78.41, 2.118, 2.697, -1.434, -1.1097046576093785],
So, if you take:
Proj4js.defs["EPSG:23030"] = "+proj=utm +zone=30 +ellps=intl +units=m
+no_defs";
And add +towgs84:
+togs84=-157.89,-17.16,-78.41,2.118,2.697,-1.434,-1.1097046576093785
+no_defs"
The projection might work out better.
CCing metacrs so that someone can tell me if I'm wrong here.
Regards,
Christopher Schmidt
MetaCarta
More information about the Dev
