[OpenLayers-Dev] RV: Dev Digest, Vol 29, Issue 31
Vidal, Antoni antoni.vidal at icc.cat
Thu Feb 26 02:34:00 EST 2009
Hello,
I have the same problem but my application goes online and if I try to load local gml I get:  "Access to restricted URI denied"  code: "1012", There is any option to load local data in in online application?
I think the "my maps" in Google maps do it, because is possible to specify a local path of a kml file located on the local machine.
Regards.
Antoni Vidal.
-----Missatge original-----
De: dev-bounces at openlayers.org [mailto:dev-bounces at openlayers.org] En nom de dev-request at openlayers.org
Enviat: miércoles, 25 de febrero de 2009 18:00
Per a: dev at openlayers.org
Tema: Dev Digest, Vol 29, Issue 31
Send Dev mailing list submissions to
To subscribe or unsubscribe via the World Wide Web, visit
	http://openlayers.org/mailman/listinfo/dev
or, via email, send a message with subject or body 'help' to
You can reach the person managing the list at
	dev-owner at openlayers.org
When replying, please edit your Subject line so it is more specific
than "Re: Contents of Dev digest..."
Today's Topics:
   1. Load external GML file in OpenLayers (Gorka L?pez Rivacoba)
   2. Re: Load external GML file in OpenLayers (Andreas Hocevar)
Message: 1
Date: Wed, 25 Feb 2009 16:50:46 +0100
From: Gorka L?pez Rivacoba <gorka.lopez.rivacoba at gmail.com>
Subject: [OpenLayers-Dev] Load external GML file in OpenLayers
To: "dev at openlayers" <dev at openlayers.org>
Message-ID:
	<f9537cf80902250750w3b4325c1jcba8727817a7f7d0 at mail.gmail.com>
Content-Type: text/plain; charset="iso-8859-1"
Hello,
I have an application an I want to load an external GML file. When I load it
from an internal file (like ".\file.gml") it's ok, but when I load from an
external file (like "C:\file.gml") there is an error: in this line:
C:\DesarrolloTINSA\mfbase\openlayers\lib\OpenLayers\Request\XMLHttpRequest.js:
this._object.open(sMethod, sUrl, bAsync, sUser, sPassword);
I don't have any problem with permissions, because it is for internal
porpouse. Is there any solution to this problem?
Thanks. Best regards,
Gorka L?pez
URL: http://openlayers.org/pipermail/dev/attachments/20090225/4125b761/attachment.html
Message: 2
Date: Wed, 25 Feb 2009 11:02:02 -0500
Subject: Re: [OpenLayers-Dev] Load external GML file in OpenLayers
To: Gorka L?pez Rivacoba <gorka.lopez.rivacoba at gmail.com>
Cc: "dev at openlayers" <dev at openlayers.org>
Message-ID:
	<5b021dd0902250802l5a91f48q21197dc3b9f176b4 at mail.gmail.com>
Content-Type: text/plain; charset=ISO-8859-1
2009/2/25 Gorka L?pez Rivacoba <gorka.lopez.rivacoba at gmail.com>:
Although you think so, the browser sees a security problem here. See
http://en.wikipedia.org/wiki/Same_origin_policy for more details.
Are you planning to go online with your application? If this is
designed to run off disk, you should use corect file urls, like this:
file:///C:/file.gml
Regards,
Andreas.
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
Dev mailing list
Dev at openlayers.org
End of Dev Digest, Vol 29, Issue 31
More information about the Dev mailing list
