[OpenLayers-Dev] RV: Dev Digest, Vol 29, Issue 31
Christopher Schmidt
crschmidt at metacarta.com
Thu Feb 26 08:49:48 EST 2009
On Thu, Feb 26, 2009 at 08:34:00AM +0100, Vidal, Antoni wrote:
> Hello,
> I have the same problem but my application goes online and if I try to load local gml I get: "Access to restricted URI denied" code: "1012", There is any option to load local data in in online application?
No.
> I think the "my maps" in Google maps do it, because is possible to specify a local path of a kml file located on the local machine.
Presumably, if you do this, you upload the file to Google's servers.
I've just tested this functionality, and can confirm that this is the
case.
Regards,
Christopher Schmidt
MetaCarta
More information about the Dev
