[OpenLayers-Dev] IE cluster/protocol error - 'status' is null
or not an object
Ivan Grcic
ivan.grcic at geofoto.hr
Fri Jan 9 05:22:12 EST 2009
Hi Tim,
just one question before i try the patch... has
http://openlayers.org/dev/OpenLayers.js been changed after I reported
the issue? Cuz I cant reproduce the error now on
http://openlayers.org/dev/examples/strategy-cluster.html !?
Tnx, Ivan
On Fri, Jan 9, 2009 at 5:45 AM, Tim Schaub <tschaub at opengeo.org> wrote:
> Hey-
> Andreas Hocevar wrote:
>> Hi,
>> On Wed, Dec 10, 2008 at 12:02 AM, Ivan Grcic <ivan.grcic at geofoto.hr>
>> wrote:
>>> HI, can please somebody confirm this? tnx
>> yes, I can confirm this. But unfortunately I have not figured out yet
>> what might be causing it.
> Is this still a problem after http://trac.openlayers.org/changeset/8581 ?
> If so, please send along a ticket number.
> Thanks,
> Tim
>> Can you create a ticket (or point me to it if there is already one
>> that I missed)?
>> Thanks!
>> Andreas.
>>> On Thu, Dec 4, 2008 at 11:01 AM, Ivan Grcic <ivan.grcic at geofoto.hr>
>>> wrote:
>>>> Hi,
>>>> aaargh another IE(7) issue :( It occurs on IE when youre using
>>>> cluster strategy.
>>>> Its easily reproducible:
>>>> 1) open http://openlayers.org/dev/examples/strategy-cluster.html ->
>>>> everything shows up ok
>>>> 2) hit refresh ur enter the page again (hit enter on url address) -
>>>> cluster dont appear and attached error shows up ;(
>>>> 3) you can reload page again and again and again.....move/zoom map
>>>> hoping the features will load...... but nothing happens until you dont
>>>> clear ur IE cache and load page again!
>>>> I dont know if its a problem about protocol or cluster....
>>>> Please do you know how can this be quickly solved?
>>>> Thank you!
>>>> Regards,
>>>> Ivan Grcic
>>> Ivan Grcic
>>> Dev mailing list
>>> Dev at openlayers.org
>>> http://openlayers.org/mailman/listinfo/dev
> Tim Schaub
> OpenGeo - http://opengeo.org
> Expert service straight from the developers.
More information about the Dev
