[OpenLayers-Dev] IE cluster/protocol error - 'status' is null
or not an object
Christopher Schmidt
crschmidt at metacarta.com
Fri Jan 9 06:08:54 EST 2009
On Fri, Jan 09, 2009 at 11:22:12AM +0100, Ivan Grcic wrote:
> Hi Tim,
> just one question before i try the patch... has
> http://openlayers.org/dev/OpenLayers.js been changed after I reported
> the issue? Cuz I cant reproduce the error now on
> http://openlayers.org/dev/examples/strategy-cluster.html !?
Yes, that code is updated immediately after SVN Commits.
> Tnx, Ivan
> On Fri, Jan 9, 2009 at 5:45 AM, Tim Schaub <tschaub at opengeo.org> wrote:
> > Hey-
> > Andreas Hocevar wrote:
> >> Hi,
> >> On Wed, Dec 10, 2008 at 12:02 AM, Ivan Grcic <ivan.grcic at geofoto.hr>
> >> wrote:
> >>> HI, can please somebody confirm this? tnx
> >> yes, I can confirm this. But unfortunately I have not figured out yet
> >> what might be causing it.
> > Is this still a problem after http://trac.openlayers.org/changeset/8581 ?
> > If so, please send along a ticket number.
> > Thanks,
> > Tim
> >> Can you create a ticket (or point me to it if there is already one
> >> that I missed)?
> >> Thanks!
> >> Andreas.
> >>> On Thu, Dec 4, 2008 at 11:01 AM, Ivan Grcic <ivan.grcic at geofoto.hr>
> >>> wrote:
> >>>> Hi,
> >>>> aaargh another IE(7) issue :( It occurs on IE when youre using
> >>>> cluster strategy.
> >>>> Its easily reproducible:
> >>>> 1) open http://openlayers.org/dev/examples/strategy-cluster.html ->
> >>>> everything shows up ok
> >>>> 2) hit refresh ur enter the page again (hit enter on url address) -
> >>>> cluster dont appear and attached error shows up ;(
> >>>> 3) you can reload page again and again and again.....move/zoom map
> >>>> hoping the features will load...... but nothing happens until you dont
> >>>> clear ur IE cache and load page again!
> >>>> I dont know if its a problem about protocol or cluster....
> >>>> Please do you know how can this be quickly solved?
> >>>> Thank you!
> >>>> Regards,
> >>>> Ivan Grcic
> >>> Ivan Grcic
> >>> _______________________________________________
> >>> Dev mailing list
> >>> Dev at openlayers.org
> >>> http://openlayers.org/mailman/listinfo/dev
> > Tim Schaub
> > OpenGeo - http://opengeo.org
> > Expert service straight from the developers.
> Dev mailing list
Christopher Schmidt
MetaCarta
More information about the Dev
