[OpenLayers-Dev] Feature's reference to it's layer
Eric Lemoine eric.c2c at gmail.com
Mon Jan 12 11:22:37 EST 2009
Hi. Nothing planned. It's not an API property so it can be renamed or
removed at any time. Though practically there's I think little chance
it'll be renamed or removed in the 2.x series.
Cheers,
Eric
2009/1/12, Joao Duarte <joao.c.duarte at co.sapo.pt>:
> Hi,
> We've implemented  a handler similar to the OpenLayers.Handler.Feature. In
> this handler, there's a need to access the layer of each feature the handler
> is associated to.
> For now, we do it using the layer property of the feature. Although, this
> property is not listed as API Property, in opposition for example to the map
> reference which each layer has.
> My question is if there are any changes scheduled for the layer property in
> the feature. Name change? Deletion?
> Best regards,
> João Duarte
> SAPO Maps
> http://mapas.sapo.pt
More information about the Dev mailing list
