[OpenLayers-Dev] Feature's reference to it's layer
Zac Spitzer zac.spitzer at gmail.com
Mon Jan 12 19:20:36 EST 2009
I'm using it as well, it's very useful
On Tue, Jan 13, 2009 at 3:22 AM, Eric Lemoine <eric.c2c at gmail.com> wrote:
> Hi. Nothing planned. It's not an API property so it can be renamed or
> removed at any time. Though practically there's I think little chance
> it'll be renamed or removed in the 2.x series.
> Cheers,
> Eric
> 2009/1/12, Joao Duarte <joao.c.duarte at co.sapo.pt>:
>> Hi,
>> We've implemented  a handler similar to the OpenLayers.Handler.Feature. In
>> this handler, there's a need to access the layer of each feature the handler
>> is associated to.
>> For now, we do it using the layer property of the feature. Although, this
>> property is not listed as API Property, in opposition for example to the map
>> reference which each layer has.
>> My question is if there are any changes scheduled for the layer property in
>> the feature. Name change? Deletion?
>> Best regards,
>> João Duarte
>> SAPO Maps
>> http://mapas.sapo.pt
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
Zac Spitzer -
http://zacster.blogspot.com
+61 405 847 168
More information about the Dev mailing list
