[OpenLayers-Dev] Feature's reference to it's layer
Andre Pereira de Matos andre.matos at co.sapo.pt
Tue Jan 13 05:32:24 EST 2009
The question is not if it is useful or not.
The question is, will the openlayers team change/delete it in a next release? It is not API Property...
We want to integrate their new releases, without any impact.
Regards,
André Matos
http://mapas.sapo.pt
-----Original Message-----
From: dev-bounces at openlayers.org [mailto:dev-bounces at openlayers.org] On Behalf Of Zac Spitzer
Sent: terça-feira, 13 de Janeiro de 2009 00:21
To: Eric Lemoine
Cc: OpenLayers dev mailing list
Subject: Re: [OpenLayers-Dev] Feature's reference to it's layer
I'm using it as well, it's very useful
On Tue, Jan 13, 2009 at 3:22 AM, Eric Lemoine <eric.c2c at gmail.com> wrote:
> Hi. Nothing planned. It's not an API property so it can be renamed or
> removed at any time. Though practically there's I think little chance
> it'll be renamed or removed in the 2.x series.
> Cheers,
> Eric
> 2009/1/12, Joao Duarte <joao.c.duarte at co.sapo.pt>:
>> Hi,
>> We've implemented  a handler similar to the OpenLayers.Handler.Feature. In
>> this handler, there's a need to access the layer of each feature the handler
>> is associated to.
>> For now, we do it using the layer property of the feature. Although, this
>> property is not listed as API Property, in opposition for example to the map
>> reference which each layer has.
>> My question is if there are any changes scheduled for the layer property in
>> the feature. Name change? Deletion?
>> Best regards,
>> João Duarte
>> SAPO Maps
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
Zac Spitzer -
http://zacster.blogspot.com
+61 405 847 168
Dev mailing list
More information about the Dev mailing list
