[OpenLayers-Dev] Size of Library / Packing
    Christopher Schmidt
    crschmidt at metacarta.com
    Wed Jan 21 12:05:17 EST 2009
On Wed, Jan 21, 2009 at 10:43:16AM -0600, Erik Uzureau wrote:
> I came across the following quote in a blog entry today:
> "The initial implementation I was working with utilized
> OpenLayers<http://openlayers.org/>,
> ... Unfortunately the size of the library seems to be constantly increasing
> (~200K in the last year) and currently weighs in at 560K uncompressed ... "
> [1]
It looks like the place you found that is a spam aggregator, reblogging
URLs to gain traffic; or at least someone who is improperly crediting
their source. The original of this article is available at:
http://blog.kapilt.com/2008/11/30/sharing-large-images-openlayers-gsiv-modestmaps-deepzoom-and-python/
"OpenLayers supports custom build profiles including only the pieces you
care about. A simple map â just dragging and WMS tiles â clocks
in at about 110k â and has been within 20% of that for most of the
2.x series (now two years running). Information on using the build tools
to build your own build are available at
http://trac.openlayers.org/wiki/Profiles . Once you take the 110k and
run it through gzip, youâre down to ~25k â not that much larger
than the binary ModestMaps builds that I checked out (which clocked in
at 18kb, but didnât compress much/at all with gzip)."
So, compared to a simple Flash implementation, with none of the
hooks/bells/whistles that OL has, we're about 30% larger, once you get d
own to brass tacks. At that point, you're smaller than a single map tile
from just about any mapping service difference, so compressing the
library itself much further doesn't gain you much.
Regards,
Christopher Schmidt
MetaCarta
More information about the Dev
