[OpenLayers-Dev] ActionScript3 port of openlayers
Erik Uzureau euzuro at gmail.com
Sat Jan 24 12:21:36 EST 2009
Looks like you are well on your way. The OpenScales project sounds
interesting and I'm sure
everyone here in OpenLayerslandia will be interested to see how things
progress.
Good luck!
Erik
2009/1/24 Bouiaw <bouiaw at gmail.com>
> Hi,
> AsOpenLayers contributors proposed to change the name of the project,
> mainly because technically we won't stay very close of OpenLayers in terms
> of API, even if we want to port some OpenLayers functionalities. Our
> ActionScript 3.0 map client project name is OpenScales. Our homepage is
> http://openscales.org
> Regards,
> Bouiaw
> On Tue, Jan 13, 2009 at 2:50 PM, Bouiaw <bouiaw at gmail.com> wrote:
>> Hi,
>> We have published a first proposal of AsOpenLayers project :
>> http://code.google.com/p/asopenlayers/wiki/Roadmap
>> Feel free to send us feedback here or on our google groups :
>> http://groups.google.com/group/asopenlayers/browse_thread/thread/197dc42166e5b7ff
>> Additionnaly, I would like to check with you that there is no issue for
>> you that we use AsOpenLayers name.
>> We really would like to implements OpenLayers functionnalities (WMS,
>> WMS-C, WFS in different projections), and if possible, have an OpenLayers
>> style API. Our licence is BSD too, so I think the name really make
>> understand what there is behind.
>> Also, even if you are not directly interested by working with us on an AS3
>> port, we would be really pleased to discuss with you about different things
>> that we are going to implement in order to compare Javascript and AS3
>> technologies.
>> Regards,
>> Bouiaw
>> On Tue, Dec 16, 2008 at 11:02 PM, Bouiaw <bouiaw at gmail.com> wrote:
>>> Just to fix what I said previously ;-)
>>> The slides were a bit outdated. Since EcmaScript 3.1 (Javascript++)
>>> killed EcmaScript4 (=ActionScript3) at Oslo summit (
>>> http://ejohn.org/blog/ecmascript-harmony/,
>>> http://www.mikechambers.com/blog/2008/08/14/actionscript-3-and-ecmascript-4/), what I said about an unified Javascript 2 and ActionScript 3 is not
>>> really possible any more. Sorry for the mistake.
>>> Anyway, feedbacks about OpenLayers AS3 port are still welcomed !
>>> I would also be interested to know if you have began to think about an
>>> EcmaScript 3.1 version of OpenLayers.
>>> On Tue, Dec 16, 2008 at 7:51 PM, Bouiaw <bouiaw at gmail.com> wrote:
>>>> Thanks for the link, I didn't knew ModestMap, it seems to be a nice
>>>> AS2/AS3 map viewer.
>>>> I will have a look to their zoom and pan code, it seems to be really
>>>> fast !
>>>> I continue to be interested by an AS3 OpenLayers port, since it should
>>>> be really great to keep most of the OpenLayers class architecture. A
>>>> Javascript OpenLayers developer may be able to reuse his OpenLayers
>>>> knowledge on the AS3 port. However, it is clear that some parts, tightly
>>>> linked to the script technology used, will be different.
>>>> A key point in my interest for an AS3 OpenLayers is to anticipate a
>>>> Javascript2 port that could run directly in future browsers like Firefox 4
>>>> (it may sounds a little silly, but I think it is not ;-).
>>>> You can see the great presentation Tamarin and ECMAScript4 here :
>>>> http://www.slideshare.net/jeresig/tamarin-and-ecmascript-4/1
>>>> I think that ActionScript3, Javascript2 and ECMAScript4 are really
>>>> close, and I am sure that from an AS3 OpenLayers, creating a Javascript 2
>>>> version will not be so complicated.
>>>> I think with a good software design, we will be able to keep separated
>>>> pure AS3 code, and Adobe/Flash/Flex tainted code.
>>>> On Tue, Dec 16, 2008 at 5:59 PM, Schuyler Erle <schuyler at nocat.net>wrote:
>>>>> On Tue, 2008-12-16 at 11:44 -0500, Christopher Schmidt wrote:
>>>>> > On Tue, Dec 16, 2008 at 05:31:22PM +0100, Bouiaw wrote:
>>>>> > > Hi,
>>>>> > > I would like to have your advice about implementing openlayers in
>>>>> > > ActionScript3. From my point of view, combining OpenLayers class
>>>>> model,
>>>>> > > ActionScript3 power, AMF3 data services efficiency and Flash vector
>>>>> and 3D
>>>>> > > capabilities may be very exiting.
>>>>> Have you looked at Modest Maps?
>>>>>  http://modestmaps.com/
>>>>> SDE
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20090124/b5f02afa/attachment.html
More information about the Dev mailing list
