[OpenLayers-Dev] Feature disappears when zoom in to the last level
on IE
Albert Rovira
arovira at ngeografics.com
Mon Jan 26 07:49:41 EST 2009
I have a line feature that disappears when I zoom-in to the last level
of the map. It only happen on IE browsers on FF works well.
I build a test with
http://www.openlayers.org/dev/examples/vector-formats.html
I modify the relative URL to absolute and added a PanZoomBar control.
Then I added a feature with WKT:
LINESTRING(2.8232342584766705 41.982597569578594, 2.820341683261403
41.98207671395145, 2.816577742220418 41.98299154728675,
2.8127958348737487 41.982363852836976, 2.810765642331356
41.9826643456329, 2.8038665809483576 41.98210342460008,
2.8006685785364467 41.98142897729179, 2.7957817433901564
41.985629131861195, 2.7931406964544774 41.98695122174946,
2.794021045433037 41.988199836989594, 2.7926017072839304
Line definition is bigger. I can post it if you need.
I zoom-in over the feature and when I'm at level zero it disappears.
Is it a known limitation on IIS ? Is it a bug ? Anyone can help me ?
Thanks,
Albert.
More information about the Dev
