[OpenLayers-Dev] multipleSelectFeature on one layer
Alexandre Dube adube at mapgears.com
Mon Jan 26 13:19:51 EST 2009
Hey,
Eric Lemoine wrote:
> Hi
> If I understand you correctly, on unselect you always redraw the
> feature after removing the intent from the intents array, right?
Yes
> Does your logic work with two controls, two of which having the same
> render intent. If the intents array is ["a", "b", "a"], I fear that an
> not the proper intent will be removed. Am I wrong?
It does, because having the same renderIntent == having the same style
applied.  The only issue remaining is : does the layer need to keep its
selectedFeatures array ?
Alexandre
> Cheers,
> Eric
> 2009/1/26, Alexandre Dube <adube at mapgears.com>:
>> Hi Eric,
>>   You're right.  So instead of removing the last renderIntent from the
>> stack, we need to remove the last renderIntent of the current SelectFeature.
>>   SFC = SelectFeature Control
>>   RIA = renderIntents array
>>   Let's say the mouse goes hover a feature and get selected by a 1st SFC :
>>   RIA : ["temporary"]
>>   Then the user click it to select it with an other SFC :
>>   RIA : ["temporary", "select"]
>>   Then the mouse goes out of the feature, unselecting it from the 1st SFC :
>>   RIA : ["select"]
>>   The feature is still drawn with the "select" renderIntent.  What do
>> you think ?  With this, you don't need to have 4 different
>> possibilities.  The user can define an infinite number of different
>> renderIntents, have a styleMap defining each one of them.
>> Alexandre
>> Eric Lemoine wrote:
>>> Hi Alex
>>> Consider this sequence: mouse goes over feature, feature is clicked
>>> (for selection), and clicked again (for unselection). With your "stack
>>> of intents" logic, the feature isn't redrawn as a result of the second
>>> click; instead it should be redrawn with the hover control's render
>>> intent, shouldn't it?
>>> Eric
>>> 2009/1/23, Alexandre Dube <adube at mapgears.com>:
>>>> Hi devs,
>>>>   Eric was right :
>>>> A first note. The current select feature implementation should
>>>> accomodate this use case: two controls on the same layer, one working
>>>> on click and the other on hover, only one of them actually changing
>>>> the feature style. This is achievable by registering a
>>>> beforefeatureselected listener, and have this listener return false.
>>>> Adding beforefeatureunselected might help fully accomodate that use
>>>> case.
>>>> Now if we want the two controls to do feature styling, we need the
>>>> stuff I mentioned previously - per-control selectedFeatures arrays and
>>>> events. But this is unfortunately not sufficient. Use case: two
>>>> controls, one working on click and the other on hover, both doing
>>>> feature styling but with different render intents. If we have this
>>>> sequence "mouse goes over feature, mouse clicks feature, mouse goes
>>>> out of feature", then the feature ends up being rendered with the
>>>> "default" render intent, while it's still selected from the click
>>>> control's perspective. In most cases, this isn't desirable I think.
>>>> At this point I don't have a solution to the above issue.
>>>> An idea that could resolve this issue : features could have a stack of
>>>> renderIntent instead of a normal string value.  Instead of assigning new
>>>> renderIntent value, it would stack in renderIntents array.  Instead of
>>>> reseting to "default", it would remove the last renderIntent in the
>>>> stack.  When the stack is empty, the "default" renderIntent is applied.
>>>>   That could work.  I'll try this and come back with more details.
>>>> Alexandre
>>>> Alexandre Dube wrote:
>>>>> Hi devs,
>>>>>   I would like to propose some changes about the SelectFeature control.
>>>>>   First, I'll introduce what I want to do : I want to change the color
>>>>> of a feature while the mouse is over it without selecting it.  I managed
>>>>> to do this by building a customized control similar to the SelectFeature
>>>>> control named HighlightFeature.  I shared the code and some people
>>>>> showed interest in this feature.  In fact, it was a good enough to be
>>>>> added to trunk but there was a problem : it's too similar to the
>>>>>   My first new option was to modify the SelectFeature control to be able
>>>>> to select and highlight.  That's what I did, but I hit a wall : I needed
>>>>> to add more new events "beforefeaturehighlighted", "featurehighlighted",
>>>>> etc.  a new array of highlightedFeatures, etc...  That also became a
>>>>> pain because it was yet an other duplication of something already
>>>>> existant ( similair "select" feature events, an array of selected
>>>>> features, etc....)
>>>>>   SO, that brings me to this solution, the first one Eric Lemoine
>>>>> proposed : an array of selectedFeatures and select events for the
>>>>> control ( without removing the ones of the layer ).  Doing that, one
>>>>> vector layer could have multiple select feature controls that would know
>>>>> which feature it has selected, they could all have a different
>>>>> renderIntent value ( this is already possible ) or their own style.
>>>>> Then, the user could interact directly with the desired control's
>>>>> selectedFeatures.
>>>>>   My example : One SelectFeature that select on click, has the default
>>>>> render intent "select", on which I register a "featureselected" to
>>>>> display a form to fill.  And one other SelectFeature that select on
>>>>> hover, has a custom render intent "temporary" to have a different color
>>>>> and an event registered to "featureselected" to display a quick popup of
>>>>> the infos of the hovered feature.
>>>>>   Even my DeleteFeature control I created a couple of weeks ago could
>>>>> work by using an other SelectFeature control and using its own
>>>>> featureSelected array.
>>>>>   I'll make thoses small changes, an example and propose this as an
>>>>> enhancement.  What do you think ?
>>>>>   Regards,
>>>> Alexandre Dubé
>>>> Mapgears
>>>> www.mapgears.com
>>>> _______________________________________________
>>>> Dev mailing list
>>>> Dev at openlayers.org
>>>> http://openlayers.org/mailman/listinfo/dev
>> Alexandre Dubé
>> Mapgears
>> www.mapgears.com
Alexandre Dubé
Mapgears
www.mapgears.com
More information about the Dev mailing list
